Help Evo pulls left
Old Nov 27, 2011 | 09:21 AM
deworley's Avatar
Help Evo pulls left
Help. My low milage Evo 8 has been cornered balanced and aligned and if I let go of the wheel at normal speed it turns to the left. Any ideas?
Old Nov 27, 2011 | 12:37 PM
gsrboi80's Avatar
Road, **** poor alignment, something bent
Old Nov 27, 2011 | 01:15 PM
ILoveAWD's Avatar
check your subframe, control arms to see it they'er bent, if not then just a poor alignment.
Old Nov 27, 2011 | 05:56 PM
WhItEVIII's Avatar
Tie rods also, if you've hit curves even a slight bump might throw off your allignment. Happened to me not to long ago.
Old Nov 27, 2011 | 07:12 PM
barneyb's Avatar
I had my Evo out today on summer tires and in freezing conditions and it was pulling all over the place. That is the new normal for me until it gets warm again.
Old Nov 28, 2011 | 01:18 AM
3K's Avatar
3K
check your tire pressure.
Old Nov 28, 2011 | 07:26 AM
yellowcr's Avatar
have u adjusted ride height recently ?
Old Nov 29, 2011 | 08:31 AM
VRSF Tiago's Avatar
Sounds like an alignment issue.
Old Nov 29, 2011 | 02:46 PM
Heezayx's Avatar
Definitely an allignment issue
Old Nov 29, 2011 | 02:53 PM
Revo15's Avatar
if your alignment is perfect check your camber bolts...tip : the arrows on the bolts should be pointing towards you..trust me had that prob for a month n finally fixed it but it could also be your tires..so rotate them first and see if that helps if not just take out ur front wheels n fixed the camber bolts!
Old Nov 29, 2011 | 02:54 PM
03evo8racer's Avatar
Sounds like an alignment issue like they stated. Sometimes the smallest bumps will knock your alignment off..
Mackman
Feb 16, 2017 02:59 PM
Moussa93
For Sale - Cars For Sale
Apr 25, 2016 01:15 PM
opjohnsmith
For Sale - Part Outs
May 20, 2015 03:05 PM
kkmoslehpour
Apr 29, 2014 01:10 AM
Evorally
Asian Forum
Jan 9, 2005 02:23 PM
