4g64 evo swap? -edited-
Old Dec 3, 2011 | 12:30 AM
Jabu's Avatar
Question 4g64 evo swap? -edited-
I've been searched for hours on this and i can't find much on it..
I have a long block 4g64 and a complete evo8 (with a cracked block)
So i was going to swap everything from the 2.0 over and then stick the 2.4 in and get everything buttoned up before deciding if i want to
build the 2.4 or sell the whole car.
So far i have some adjustable cam gears and a water pump spacer.
I need some tips or a guide on swapping the head over because i don't want to F that up..
Thanks guys,
Jabu
Last edited by Jabu; Dec 3, 2011 at 10:13 AM. Reason: was really late the first time lol
Old Dec 4, 2011 | 06:40 PM
Jabu's Avatar
To clarify, i just would like to know if there is any problem with swapping everything over to make an evo 2.4 and also if i could have some tips, guide, walk through or something along those lines on the head swap and keeping the time and all that
Thanks,
Jabu
Old Dec 4, 2011 | 08:24 PM
mrg72433's Avatar
The stock 64 pistons are fairly weak so be careful with that, evo rods are the same as the 64's and the 64 crank is longer stroke. You are going to need the 63 water pipe
Old Dec 4, 2011 | 08:41 PM
n2oiroc's Avatar
http://www.amsperformance.com/instru...llPictures.pdf
Old Dec 20, 2011 | 07:05 AM
Jabu's Avatar
How much of that relates to a stock 4g64?
Jabu
Feb 7, 2012 02:02 PM
Jabu
19
Dec 27, 2011 07:09 PM
Jabu
Dec 21, 2011 06:08 PM
Jabu
Dec 20, 2011 05:37 AM
turbolancer02
Lancer Engine Tech
May 7, 2010 10:22 AM
