Help me get to 400whp
Old Dec 8, 2011 | 10:32 PM
guyver858's Avatar
Hello All!
Please see my mod list below. What can I do in addition to get to 400awhp? I wanna do it on 91 octane pump gas and stock bottom end. I currently have about 340hp/300tq on mustang dyno.
Old Dec 8, 2011 | 10:39 PM
EvoFredo's Avatar
how much boost are you running on the current set up? also a ported intake manifold and 65mm TB would help a bunch. 340whp is pretty stout already.
Old Dec 8, 2011 | 10:55 PM
guyver858's Avatar
boost peaks at 24 and tapers to 21.
Old Dec 9, 2011 | 10:29 AM
EvoG8r's Avatar
You would think with your mods you'd have already gotten there. I have same turbo with no cams and I was a little short too. I picked up a SpoolinUp COP and it feels like I added 10whp.
Old Dec 9, 2011 | 10:39 AM
PaperClip's Avatar
He said his was on a mustang dyno...so he is actually making a good bit for what he has.
Old Dec 9, 2011 | 01:13 PM
rubio2325's Avatar
help this man reach his goal also if someone can go on my thread and give me some pointers as well
Old Dec 9, 2011 | 01:20 PM
CurseDSM's Avatar
Get a new tuner you should be way over that with that setup. Even mustang #s you should be there by now. Just noticed you said on 91 octain. I would look into a Labonte meth kit with a #7 or 10 jet and a 50/50 mix. Also as someone said ported intake and 65mm tb.
Old Dec 9, 2011 | 01:23 PM
4RETECH's Avatar
^^^^+1
But the 91 is a limiting factor too
Old Dec 9, 2011 | 01:29 PM
CurseDSM's Avatar
Originally Posted by 4RETECH
^^^^+1
Yes but with the 50/50 mix it will actually help some. It will also keep your interrior heat to a minimum which will help with teh 91 gas. 93 would be better but if it isn't available thats the best he can get. I suggested the Labonte kit being I have one installed but went e85 because it has a built in fail safe.
Old Dec 11, 2011 | 09:31 AM
guyver858's Avatar
No meth for me. I'll be road racing the car so wouldn't be the safest choice. I wish I had access to e85. Seems like everyone is making huge power with the switch to corn. Would ported IM/TB, UICP, and spoolinup cop get me to 400?
Old Dec 11, 2011 | 09:41 AM
CurseDSM's Avatar
How is meth not safe if you don't mind me asking? You put 5 bottles of heet in a 1 gallon container fill the rest with distilled water how is that not safe?
Old Dec 11, 2011 | 09:58 AM
guyver858's Avatar
^^When the system fails. I'd prefer not to add the complexity.
Old Dec 11, 2011 | 10:27 AM
vortecd's Avatar
Anything can fail. Meth works great! I have been running it on my Mustang for 4 years.
Old Dec 11, 2011 | 10:32 AM
vortecd's Avatar
As far as the 400hp goes, what does it run at the track? A dyno is a tuning tool and they all can read different. On a different dyno you could already have 400hp. MPH at a track will show you the hp you are making. That is why we don't race dyno's.
Old Dec 11, 2011 | 10:35 AM
kyoo's Avatar
Very interesting - powerwise I have VERY similar mods to you, except less aggressive cams (GSC S1's), higher boost (26psi), and 93, etc.
Definitely recommend the spoolinup COP, you will pick up smoothness/small amt of power there, and then after everything I've heard recently, I'd get off the Reese tune, maybe contact Mitch@AMS.
btw, how much difference is there with that particular mustang compared to a dyno? I just brushed 400 on VD in 30deg weather, on a slight uphill actually
