fp red evo 8-help please
Old Dec 21, 2011 | 09:16 PM
chaosfiend21's Avatar
Unhappy fp red evo 8-help please
Long story short...Recently bought an evo 8, the car was on a conservative tune and had some issues so I decided to get it retuned. Made 403whp 343wtq on stock cams 93oct. Decided to get HKS 272's since car is a DD I figured this would get me to my goal of 450whp. Well after installing the cams car is not making hardly any power.
Setup:
Stock block
HKS 272's
FP Red 84mm jb with 25psi actuator
Tial Q Bov
Nisei Intake pipe w/K&N Filter
Nisei licp & uicp
APS 3.5" FMIC
Megan 02 Housing
HKS downpipe
Custom test pipe
HKS catback
Speed Density Conversion
ECU Controlled Boost
Walbro 255
ID 1000cc
BPR8ES Gapped to .024(Installed today)
ACT Clutch and Flywheel
Any Suggestions on what to troubleshoot would be appreciated. Graph is attached.
Last edited by chaosfiend21; Dec 21, 2011 at 09:24 PM. Reason: added bov fuel system
Old Dec 21, 2011 | 09:32 PM
binky's Avatar
Was the car re-tuned after the cams were installed? How much boost are you running?
-Bink
Old Dec 21, 2011 | 11:15 PM
yes we are trying to retune but can't get more power than what the graph shows boost is 27psi.
Old Dec 21, 2011 | 11:20 PM
02-Lancer-Es's Avatar
It could be off timing ..
Old Dec 21, 2011 | 11:22 PM
prowakeskater's Avatar
cams were installed wrong, you're off a tooth
Old Dec 21, 2011 | 11:29 PM
Thanks guys...Checking for timing tomorrow.
Old Dec 22, 2011 | 05:42 PM
Right on the money....2 teeth off
Old Dec 22, 2011 | 07:01 PM
Spec-Ops1's Avatar
I figured with the turbo spooling up 1500rpm late...
Old Dec 22, 2011 | 07:39 PM
marcusE's Avatar
Stupid question. How did you know full spool was 1500rpm late from the graph? peak rpms?
Old Dec 23, 2011 | 12:42 PM
Spec-Ops1's Avatar
No, look at the boost profile... and when it is hitting full boost...
real fast
Aug 27, 2016 04:55 PM
tscompusa
Feb 24, 2015 01:20 PM
GST Motorsports
Dec 22, 2010 12:37 PM
Svendiesel
15
Mar 22, 2010 10:23 AM
razorlab
Feb 25, 2007 07:22 AM
