fuel pump wire with high/low voltage circuit
Old Feb 23, 2018 | 10:05 PM
  #286
2006EvoIXer's Avatar
Yup. I figured it out by looking at shape and looking closer at cluster. Although it shows 14 in a row, it's actuall 4, 4, and 6.
this should help
Old Feb 23, 2018 | 10:08 PM
  #287
Pink and purple wires are thin! No wonder voltage drops to much at pump!!
Old Feb 23, 2018 | 10:16 PM
  #288
Biggiesacks's Avatar
based on the wire color codes in the diagram i think the wire should be brown (2BR).
Old Feb 23, 2018 | 10:20 PM
  #289
Old Feb 23, 2018 | 11:11 PM
  #290
Doesn't look like Brown is connected to 13. Looks more likely connected to 28.
Brown makes sense and looks like 14 awg.
Old Feb 23, 2018 | 11:18 PM
  #291
Actually, I read drawing wrong. Pin 13 should be bottom row, 2nd pin:
It was upside down after all.
Old Feb 23, 2018 | 11:20 PM
  #292
yah im thinking maybe your picture is upside down, or the diagram is, having done countless car alarms in my 20's that wouldn't surprise me at all. I would usually orient the diagram based on the colors of the wires and their known positions in the connector. So if that brown is second from the left in your picture then that would match if you flipped the diagram 180 degrees.
Old Feb 23, 2018 | 11:24 PM
  #293
My picture is rightside up. I took it through the 2 dummy switch covers.
The left schematic is rotated 180 upside down.
Old Feb 23, 2018 | 11:31 PM
  #294
Yah and then when you are already upside down under the dash trying to read one of these diagrams while you work you can see how easy it is to get screwed up. Thats why i said i just locate a known color in a known position to orient the diagram. Its a nice sanity check before you start hacking into the harness
Old Feb 23, 2018 | 11:34 PM
  #295
Totally agree! Thanks for the insanity check!
I needed that!!
Old Feb 24, 2018 | 11:40 AM
  #296
So pin 14 is purple and pin 13 is brown
I decided to pull off the cover instead of camping upside down.
Only 2 philips screws and a 10mm bolt in back connected to fuse box.
Old Feb 24, 2018 | 08:48 PM
  #297
If you guys haven't done this yet consider swapping Relay #2 with Intercooler Spray Relay. Intercooler relay is probably as good as new, so retire your Relay #2 to intercooler duties.
Old Feb 24, 2018 | 09:22 PM
  #298
GregM's Avatar
Could we not use pin 39 for fuel pump speed to activate the relay instead of a hobs switch?
Old Feb 24, 2018 | 09:30 PM
  #299
Where are you seeing pin 39? This?:
Here is an album i threw together of all the pictures i took of the ECU. Many are of the same area just from different angles. http://imgur.com/a/LRxhb
To follow that up here is an image, circled in red is the only 16 pin connector on the ecu C-119 and in pink is pin 39.
Old Feb 24, 2018 | 09:39 PM
  #300
I think this discussion started on post 156
