BBK-Full DD best cam GSC s1,s2 ,Kelford??
Old Dec 30, 2011 | 04:01 PM
BLK_EvIL's Avatar
thanks for the info guys looks like i might go for the s2's now since they should be the last cam ill buy overall goal is 500hp built motor
Old Dec 30, 2011 | 09:53 PM
Nomad4g63's Avatar
Originally Posted by JohnBradley
S1s are 268s and really emphasize peak power under 7k for the most part and wicked response. S2s are 274s and definitely help make more power everywhere, but are aimed for further up the powerband. On an 8/9 the S1s will be also be invisible at idle or very very similar to stock if you want them to be. Most good tuners can make them lope if that is required. On an VIII the S2s do have a more noticeable lope, can be a challenge on a MAF if the tuner isnt familiar with the combo, but really make it sound aggressive.
Aaron
why did you guys decide to use the GSC S1 on this setup if you dont mind me asking?
http://www.youtube.com/watch?v=UiJR5...ure=plpp_video
Old Dec 31, 2011 | 07:36 AM
GG06MR's Avatar
I'm sure it's because it's a 2.4L, and they're not going to need or want to rev it out to 8k or more to make power out of it, like the smaller displacement and more rev happy 2.0L. It's like Mr. Bradley said, "S1s are 268s and really emphasize peak power under 7k for the most part and wicked response."
Old Dec 31, 2011 | 11:56 AM
4cdndctn's Avatar
For DD S1 > S2 > Kelford
Old Dec 31, 2011 | 01:49 PM
blknblubkrdude's Avatar
I went with S1's on my BBK setup. Best decision ever.
They match the BBK perfectly..... spools fast, quick response, and hold power all the way to 7000, which is as high as I rev it.
Old Dec 31, 2011 | 02:15 PM
vmrevo9's Avatar
Veteran: Air Force
truthfully the highest i rev my car is about 7.5K. i could have been fine with the S1's but i decided to go bigger just for the fact that once its done i didnt have to worry about upgrading again.
the way i see it all the cams listed are a great choice. it will all depend of the budget, and what the owner wants.
Old Jan 4, 2012 | 12:32 PM
NocturnalEVO's Avatar
what about a staggered setup? S1 intake/S2 exhaust? Does anybody do that?
I'm stepping down from a 50trim into either the BBK lite or BBK full, and my biggest concern is spool and power under the curve since I don't really get to open it up much at all.
I want low and mid-range power, and some top end would be great, but i wouldn't really get to use it as much.
Old Jan 4, 2012 | 12:41 PM
boosted91t's Avatar
^ BBK Full and never look back. Look for the ball bearing variants coming out very soon
Old Jan 5, 2012 | 05:23 AM
sparky's Avatar
I wonder whether anyone has actually logged a back-to-back comparison between the S1's and the S2's on the same car for the purpose of comparing turbo spool up between the two GSC grinds on an VIII with a BBK or similar sized stock frame turbo.
It is accepted as common knowledge that the S1's will spool a turbo quicker than the S2's, but has anyone ever gone to the trouble of logging the difference between both just with respect to turbo spool up? Any boost logs out there by someone who has switched from S2's to S1's or vice versa?
Aaron points out that according to his data the S2 produces more power than the S1 at every RPM level, even in the low-end, and I don't doubt it. But, does the S1 actually spool a turbo up quicker than its big brother?
Old Jan 5, 2012 | 06:33 AM
Paintballguy's Avatar
Get a BBK Full. I'm hitting full boost at around 3700-3800 rpms with 100% stock engine. It honestly spools like a stock turbo, and the transient response between shifts is amazing. Chad @ CBRD is really high on the BBK Full and GSC S2 combo.
863EvoXlegend
Jul 27, 2022 03:11 PM
josh_evo9
Dec 9, 2017 07:33 PM
LakerRaider
35
Sep 26, 2016 08:10 AM
will180sx
Oct 13, 2015 06:09 AM
InitialE
Oct 2, 2011 01:51 AM
