Name this mod
Name this mod
Hi guys. Got my evo bout a month ago. Love it so much that i hit the 4k mark early and needed an oil change. When i got down there, there is a sort of wire on the drain plug. When i unplugged it the plug is attatched to the line. Tried following it but it gets difficult on the garage floor. Any idea what it is? Please dont wreck me for not knowing the latest or "coolest" mod. Thanks in advance
Yea its an MR with stock gauges. Really stock? Thats interestingly wierd because it is improper to use the open end of a wrench to break the bolt but with this attatchment its impossible to do it any other way. Thanks though fellas
I always used an open ended on the drain plug. Never was an issue. The Drain plug should never be that tight. I forget the tq specs but you should not need much on there.. Was always the easiest bolt to turn on my car ... LOL I replaced mine with an aftermarket pressure gauge so don't use the plug anymore. I also went with a fumoto valve. Makes life a lot easier. no more crush washers and drain plugs...
Done
210
Apr 4, 2015 10:47 PM
