How much power can original Coils make?
Old Jan 23, 2012 | 12:22 PM
Nickolaus's Avatar
Hello, i will soon go to the tuner with my car, and i wonder of much power i can make on stock igntion coils, or if i should upgrade them, my goal is 600 hp
Thanks in advance Nicko
Old Jan 23, 2012 | 12:37 PM
AngryEvo8's Avatar
I think you should be fine with your goal of 600hp. Evosick2332 ran 700+whp on stock ignition without any issues.
Old Jan 23, 2012 | 12:47 PM
jid2's Avatar
Mine worked for about a year at 500whp, then the coils crapped out and the car started to misfire. Replaced with COP and its been doing great for over a year now.
Old Jan 23, 2012 | 12:49 PM
andrewzaragoza's Avatar
or you can just get the used coils COP from http://spoolinup.com/
ignition is like a piece of mind upgrade if you want to avoid spark blow outs.
Old Jan 23, 2012 | 01:54 PM
westheevokid's Avatar
you should be fine. they just need enough power to create combustion. i believe 13 Kv is all thats needed on most cars and nothing more. even if its a 200,000 v ignition it dose not mean its going to use all 200,000v. On the other hand if you are going to be driving hard on a pretty regular basis it wouldn't hurt to get a new ignition. you don't want ignition failure at those power levels
Old Jan 23, 2012 | 02:44 PM
Acree's Avatar
I'm running stock coils. 40k miles on them total, 5k miles at 600+hp.
-Acree
Old Jan 24, 2012 | 01:07 PM
Nickolaus's Avatar
Thankyou guys this have given me some ideas
Old Jan 25, 2012 | 06:05 AM
Mikey@Spec-Ops's Avatar
To answer your question, it really depends. Some stock coils if in good condition will support 600+whp. Like for example, Aaron@ER ran 750 on stock coils for almost a year. I am currently at 75owhp on stock coils too. I have a Spoolinup COP that I'm going to put back on the car just for the sake of it not missfiring and taking out my motor.
I highly recommend the spoolinup COP if you are a motor over 500whp if you can afford it. Matt the owner of spoolinup is a great guy too!
Mikey
mrfred
Dec 31, 2023 08:49 AM
chrisff521
Jun 8, 2012 05:53 AM
emotart
Jan 11, 2011 11:07 AM
monsta
186
Dec 12, 2009 06:30 PM
krimson_binome
Lancer Engine Tech
Aug 10, 2005 05:52 AM
