HKS 7460 GTII 'Kai' - Failures?
Old Oct 1, 2013 | 09:28 PM
  #166
EVONOT's Avatar
Hope this helps you guys for future reference. This is a fp18psi btw:
Btw nothing custom was done, and I did it with everything intact.
and heres the old one:
HKS BROKEN ROD.
SO I HOPE THIS CLEARS THE AIR FOR ALL THE PEOPLE THAT RUN THIS TURBO!!!!
You CAN run the FP 18/25psi wastegate.
Old Oct 2, 2013 | 05:20 AM
  #167
wrx2evoIX's Avatar
Thanks for posting, did you have to re-tune boost via wastegate duty cycle after the swap?
Old Oct 2, 2013 | 07:53 AM
  #168
EVONOT's Avatar
Well mine was tuned for 26 psi. But as far as idles, and afr. Stuff just kinda smoothed out. It wouldnt hurt to log a run or have a tuner see it. But im good.
Old Dec 4, 2013 | 08:34 PM
  #169
Nimpoc's Avatar
Were you ever able to get this repaired?
Originally Posted by nollij
I think I stated somehwere that I would post up if my HKS GTII 7460r failed...
Old Dec 5, 2013 | 04:08 PM
  #170
94AWDcoupe's Avatar
no. he sold that turbo to me. I have it here. it could be repaired fairly easily by machining a new shaft. But my plan was to have a 9.8cm mitsubishi housing machined to fit the turbo. I think the 9.8 housing will be an upgrade. the HKS housing looks restricted to me.. although that may be one of the reasons it spools so fast.
Old Jan 17, 2014 | 07:57 PM
  #171
EVONOT's Avatar
I have my 7460r kai version for sale if anyone wants it, with fp 18 psi wastrgate.
Old Mar 9, 2014 | 11:12 PM
  #172
lv05evo's Avatar
Sorry to bump an old thread, but isn't the HKS wastegate flapper bigger than the 9.8 cm flapper? Do you think this will present a problem for high boost? Also are you going to have a turbo shop do the machine work, or do you work at a shop that can do it for you?
Old Apr 21, 2015 | 07:40 PM
  #173
Nimpoc's Avatar
FWIW the Turbosmart Evo9 actuator works fine as well.
https://www.evolutionm.net/g/album/3306219
LCS
19
Feb 9, 2017 11:15 AM
ecl27
May 3, 2016 12:14 AM
LCS
11
Mar 31, 2016 07:58 PM
bruce988jl
Jan 16, 2016 07:38 PM
