HKS 7460 GTII 'Kai' - Failures?
is the Evo 9 hotside and the 7460's interchangeable? i've wrecked both the stock Evo 9s and 7460 WGA road racing. i've got a Forge 25psi WGA preloaded properly and it's still not holding full boost. is suspect that it might be the HKS BOV, which i'll be switching out for a Synapse BOV shortly. if i still can't hit full boost then it must be the flapper not seating properly.
also, if i bought the 7460 GTII used, who can i talk to to have it sent back to HKS Japan?
TIA
TIA
Here is the WG flapper that warped that Aaron was talking about. History of the turbo... bought from Ivey, installed and tuned by English, one track day.... problems from the turbo, English adjusted the actuator arm, second track day... more problems, then turbo came off the car to see what the heck was going on.
TIA
TIA
The scenario above is very similar to a valve that gets burned. If something sticks between the valve and the seat all the additional flow heats up the valve and the material stuck there and can cause a blowtorch effect and burn the valve. I wouldnt be surprised is the constant leaking and lack of contact allowed excessive tempuratures and warping causing a domino effect.
I would think its warping because everyone is running high preloads on the actuator. when you do that the valve barely lifts from its seat even when wide open. tons of hot gas through small space= warped arm from over heating. ultimately the arm wasnt made of the correct material. mitsu housings never warp arms.
If I were to run this turbo I would use evo 10.5 housing and machine it for the wheel.
The mitsu arm doesn't loosen up over time... and therefore doesn't float the valve off the seat.... and therefore doesn't have problems like this.
Having NO flow through the wastegate hole does not increase the temperature of the flapper. Think about having your valve lash set loose (for those of you familiar with engines other than neons/Evo's)... what does that do? It results in a burnt valve.... why? Because if you read anything about valvetrain the valve controls it's temperature through the guide and transferring heat through the seat. Of course this isn't a poppet valve, but the same principles apply.
What 94AWD is trying to say is that if you put a lot of preload the result is that at the same pressure the valve open less, and the exhaust gasses must pass in a smaller area.
But I think that it cannot be the case of the HKS turbo.
if actuator stretches first this would allow soggy boost response and allow the valve to open much farther than normal since its starting position is no longer even on the seat. both would heat the valve and arm much less since gasses would have much larger area to go through.
I bought a HKS7460 and I put it on my car and ran it for a few months.
The actuator rod WITH THE LOCK NUT TIGHT... would loosen over time. I retightened it probably 10 times in the first month.
It would loosen to the point that when the car idled it would rattle against the seat and be so audible that we stopped doing dyno pulls on the dyno because it sounded like a rod bearing.
So yes it loosens over time. Yes the actuator arm sees some temperature and yes the material properties of stainless degrade with temperature.
I ran E85... so my EGT's were pretty low... and I ran a lot of boost 36+psi. So I wasn't wastegating a ton of exhaust.
I''ve ran the HKS for about 1 year, around 26psi, daily driving, autox, and a few HPDEs this past summer. I haven't had isues with the turbo at all, and its not showing any signs of problems. I don't have the KAI version either, being I was one of the first to pick up the kit when it was released with the cam package. I haven't had R/T's issues with the wastegate actuator, but I also agree with the design not being ideal. However, I'm still using mine and its holding 26psi decently.
I must have about 20k on it by now... No issues to date. It's a DD so it rarely sees sustained beatings, maybe a couple seconds of 30 psi here and there, but nothing like RR.
I'm honestly not sure if I would even know if the WG was warped, I have my WGDC (3 port) down in the 30s in some places to keep it happy and it still pulls mighty hard down low.
I don't think mine is a Kia version. I picked it up from Ivey early September 2010, installed it a week later and drove to Ivey for a tune.
The first thing we noticed, that the W/G's Rod was loose from the factory; it was tightened up and the car was tuned.
After a couple of track events, I noticed that the lock-nuts/adjustment threads backed out a little, and the rod was loose again. It was tightened again with a good amount of force and some locktite and it's been fine for over a year now.
I DD and track my car. As a DD, I normally run 93 pump gas and around 28 psi of boost. On the track, I drop the boost to 25-26 and mix a couple gallons of 100 octane with every tank full of 93.
Is my flapper warped? I don't see it being warped and making 440/412 on 93 pump gas but, I could be wrong.
