Milky Oil issue
Old Feb 2, 2012 | 11:46 AM
izabran's Avatar
Originally Posted by BlackOperative
Also, I should add that a blown head gasket, although possible, USUALLY wont pop a freeze plug out, it will simply force more coolant through the radiator cap. Most radiator caps are around 15psi, and it takes a hell of a lot more than that to pop out a freeze plug... Not trying to offend, just so thats clear.
ill take a pic of the head gasket tonight and post it... it looks just like how it did when i had it put in...
Old Feb 2, 2012 | 12:03 PM
meckert's Avatar
Never mind--
Disavow anything I said here-- I must have been smoking something.. i could have sworn the OP said he rebuilt the motor and I assumed he meant really rebuilt it from the bottom up and had a problem after a clean build.. I clearly see that was not the case. No harm no foul.
Old Feb 2, 2012 | 01:44 PM
izabran's Avatar
Originally Posted by meckert
Never mind--
Well no... I had a spun rod bearing so I. Replaced the rods and crank with manley I beams and manley crank...
All new gaskets... rings... bearings... it ran fine no issue... until the freeze plug popped out... I then changed to my fp black and added a catch can...
The car was only started for 15 min 3 times just to idle as I was checking for leaks and waiting to put my ds bushings in...
When I found the leak I decided to drain my oil so I can pull the pan and pull the oil pump to check the gasket that's when I noticed the milky oil...
So if the block cracked after the freeze plug came out then I guess its that because the head gasket is in great shape...
Old Feb 2, 2012 | 02:10 PM
blowngasket's Avatar
u said u added a catch can, is there water at the bottom of the catch can?
Old Feb 2, 2012 | 09:13 PM
izabran's Avatar
no it's empty... that was teh first thing i looked at...
since adding the catch can and the freeze plug coming out i havent driven the car only allowed it to idle for 15 min intervals over a few days...
im thinking those that stated cracked coolant track are correct... because everything else seemed fine...
SOOO should i stick to my 2.0 with manley crank, ibeam rods and wiseco HD pistons... OR go 2.4??? and if so can i re-use any of my parts from my 2.0 block...
Old Feb 3, 2012 | 08:45 AM
i had a similar issue, with a catch can and PCV valve that wasnt working correctly. It was sucking in atmosphere air that was moist and thus creating a water pool in my catch can and then giving me milky oil. Id pressure test the engine, if it was coolant leaking you would be running higher then normal temps since it wouldnt be able to pressurize or self bleed thru the radiator cap. Youll also notice Steam Flowing from the engine once the water has entered it cause its boiling off,[thru the catch can breather] if it was a coolant mix it would take a higher temp to burn off the water/coolant mix so you wouldnt notice steam.
Pull the oil pan and pressure the engine, see if the block and or/coolant passage is leaking down.
Old Feb 3, 2012 | 09:31 AM
izabran's Avatar
yeah... i already pulled the head lol... i might have freaked out... so im going to have a machine shop check it for me... i'll keep everyone posted... hopefully it's something simpler then a cracked block...
Old Feb 3, 2012 | 10:32 AM
yeah have them do a Magna Flux on it, only bad thing is everything has to come out now.
evole97
14
Nov 10, 2021 08:06 AM
onlynamenotused
15
Oct 13, 2018 11:48 AM
MechNARP
Oct 15, 2015 05:33 AM
jherrer3
Lancer Troubleshooting
14
Dec 30, 2013 09:09 AM
heygotboost
Mar 11, 2008 10:11 AM
