oil light wont go off need advise
Old Feb 17, 2012 | 08:53 PM
bubba17's Avatar
so i ran the car 2 days in a row about 10 min a peice and everything was fine. today i get in me and a buddy are going to cruise and notice after about 2 min of running the oil light comes on and doesnt go off. now if you shut the car off and turn it on the oil light does not come on instantly but after about 3 to 4 min it stays on. heres the kick i have good pressure, and there is no blockages as i can tell, no leaks no nothing. doing research it looks like it could be a toss up between the oil sending unit or oil pressure switch. but now i am thinking it is just the switch becuse if it was the sending unit wouldnt i have low pressure? like i said oil pressure is normal idling and cruising. car is full of oil, no leaks anywhere, and pressure is perfectly normal i hope its just the switch but wanted to see what you guys think
Old Feb 17, 2012 | 10:01 PM
barneyb's Avatar
Do you have an oil pressure gauge? If the answer is yes and you trust it then you have the answers to your question - the switch/sending unit (they are the same thing and both names are correct) for the oil light is bad. If you do not have a gauge then it may be that you have no oil pressure. However, replace the switch and see if that fixes the problem.
Old Feb 17, 2012 | 10:23 PM
cmspaz's Avatar
The senders go bad all the time on these cars. I was questioning whether mine was bad or not last Fall, just said eff it and replaced it, problem solved. Turned out it had actually been out of spec since I bought the car in '10.
Old Feb 18, 2012 | 06:08 AM
bubba17's Avatar
yes there is a oil pressure gauge in side its a brand new glowshift elite 10 and i also have a glowshift oil filter adapter with temp and pressure built in. im gonna run to a local dealer today and pick up the part hopefully thats the fix
Old Feb 18, 2012 | 01:01 PM
3K's Avatar
3K
Check your sending unit if its touching anything metallic.
Old Feb 18, 2012 | 06:50 PM
bubba17's Avatar
i beleive its the sensor i got 10 olms comming out of the oil pressure sensor at the harness and i only got .4 olms comming out of the sensor its self beleive that is my problem. And 3K there is nothing touching the sending unit the oil cooler lines are close but no rubbing
Old Feb 18, 2012 | 07:05 PM
cmspaz's Avatar
You can get new sensors at O'napazonequest for like $6, I don't even want to know what the dealer charges. It's just a simple .3 bar sensor, I can't imagine OE is any higher quality considering how often we see them fail.
True Blue
Aug 1, 2016 05:35 AM
CeliOnce
16
Mar 19, 2016 07:54 AM
robertnorman06
Lancer Engine Tech
30
Feb 3, 2016 07:17 PM
EvoIX89
17
Sep 22, 2015 07:11 AM
livelyjay
32
Apr 29, 2009 10:28 PM
