Required mods for 400whp IX MR on e85?
Old Feb 20, 2012 | 02:00 AM
yaba94070's Avatar
Originally Posted by JohnBradley
1. Walbro 255lph fuel pump
2. 1000cc injectors
3. MBC
4. JMFab O2 dumphousing
5. ETS lower intercooler pipe
6. Gus mod stock IX BOV
7. Any vendors turbo back exhaust (with test pipe)
8. stock cams
9. tune
I have made 430whp on 4 separate cars that way.
This sounds like a plan...
2 questions though... GUS mod stock BOV>>>(GUS MOD???)... MBC ????
sry brevs kill me some times... thanks guys
Old Feb 20, 2012 | 09:04 AM
06MRV8Killer's Avatar
I think GUS mod is referring to a crushed stock diverted valve and the MBC is a manual boost controller
Old Feb 20, 2012 | 09:06 AM
ElectricBlueIX's Avatar
MBC means Manual Boost Controller like a Hallman. I personally have the Hallman MBC and I love it. Improved spool a tad and very accurate.
My car had the Tomei DV on it already when I bought it with no other mods so I don't know the "gus" mod to the factory IX diverter valve(DV).
I'm waiting on my Buschur street FMIC an piping to come in at the moment. After install I'm taking my car to AWDMotorsports for timing belt job, cam install, and tune looks like I shouldn't have a problem hitting 400whp mark since I'm doing a pump gas and race gas tune. I know everybody loves E85 but I don't. Never have been a fan of it. Plus I like my moderate gas mileage.
Old Feb 20, 2012 | 12:08 PM
dangle's Avatar
My synapse feels better than my stock ix valve did so if the OP isn't on a budget I would go with that. Also ecu controlled boost is superior to a mbc and with a map switch for a 93 octane and e85 tune he wouldn't have to adjust a mbc for each map. A GM 3 port is cheaper than a hallman and more accurate. Also say goodbye to gear based boost control if you get that hallman. The Grimspeed piece is nice though for a good plug and play unit.
Old Feb 20, 2012 | 01:38 PM
I had never looked into ECU controlled boost but I read up on tha Grimmspeed unit and it seems like a good way to go if your using two maps. Good advice man!
Old Feb 20, 2012 | 03:44 PM
dangle's Avatar
You are looking at it all wrong. For one you won't hit 400 on 93octane no matter how high of a reading mikes dyno is. Second your race gas map will never be the same because you will always have a certain amount of 93 still in the tank. This holds true for E85 also. Every time I swap from 93 to E85 I had to cycle at least half a tank before I got my power back. Once I filled it back up the car was good to go. This is much cheaper to do on E85 than race gas. Your gas mileage will suffer obviously but the power you gain for the price is well worth the hassle of driving fifteen minutes out of my way for e85. Unleaded race gas will never outperform E85 and leaded will ruin sensors.
Old Feb 20, 2012 | 04:09 PM
^ that
Old Feb 20, 2012 | 07:45 PM
JohnBradley's Avatar
Gus mod is not crushing the BOV. That is "crushing the BOV" where you vice down the top. Gus mod is different-
http://www.socalevo.net/gallery/disp...um=588&pos=980
Old Feb 22, 2012 | 05:03 PM
adriano_917's Avatar
Originally Posted by pure_evo
OK. Let me take a stab at this. Since you already have the stock IX turbo, I am going to assume that you do not have any other modifications for the car (100% stock). I would say this would be the easiest (and cheapest route if you are on a budget). Also assuming that 400whp is your ultimate goal and not +1whp more.
2. 880-1000cc injectors
3. 3-port boost controller for ECU-controlled boost
4. EBay O2 housing
5. Any vendors lower intercooler pipe
6. crushed stock IX BOV
8. 272-duration camshafts
9. tune
What? I have all those mods and im making 352awhp!
Old Feb 22, 2012 | 05:08 PM
dangle's Avatar
I believe he was telling the OP what mods he will need assuming e85 was his fuel of choice. I agree with all besides cams. For $1k people spend on cams I would just send my turbo to fp for a green and make a lot more power for the money.
Old Feb 25, 2012 | 11:11 AM
Thanks for the link but it doesnt really explain what is being done just pictures...
Agree with you on this one, Im at 500whp still on stock cams
Old Feb 29, 2012 | 06:58 PM
yaba94070's Avatar
Okay so shop cliam and has a few car dyno's to prove it.. intake exhaust and FMIC with tune does 380whp???
Any input!!! ????
Old Feb 29, 2012 | 08:25 PM
dangle's Avatar
Any input!!! ????
On E85 you can make 380whp with those mods. I can't stress throttle body seals enough and a boost leak test prior to your tune as every car I have worked on has leaked bad. I gained 17whp off of a $20 throttle body seal. What other mod do you know that makes that much power per dollar besides taking off your exhaust?
Old Jul 6, 2012 | 11:57 AM
ILoveAWD's Avatar
i can agree wih this because this same he made 391 maybe alittle more (because the dyno we used a drift office have been known to read low) on my 8 turbo, stock cams and e85. johnbradley know his suff. wih these mods minus the ets lower intercooler pipe but i plan to pick one up here shorly and cams and get a retune at english!
2. 1000cc injectors
3. MBC
8. stock cams
9. tune
Frankenstein
May 10, 2017 01:23 PM
febs1011
Dec 19, 2014 11:49 PM
stayboost3d
12
Nov 26, 2011 11:39 PM
Mazzab
Mitsubishi TC-SST Discussion
36
Jun 4, 2011 01:26 PM
MR 600
Automotosports - Illinois
Nov 13, 2006 01:18 PM
