My Clutch is sticking when I press it help!!
Have you check your fluid or to see if you have a leak? Air in the clutch line will will allow it to fall also. Remember that we share the brake and clutch fluid. If its so low that its got air trapped in the system I recommend that you bleed the whole system.
It happened while I was at a light. I went to take off then when I went to go shift into second the clutch was almost to the floor. I pulled it back up and continued shifting until I got to the next light then it did it again? Kinda weird.... Could it be the spring possibly?
^^ yup, or you might have a bad clutch slave cylinder, if you look where the brake master cylinder is, theres a line that goes behind the drivers side strut in the corner, to a metal piece, thats the clutch master cylinder, then follow that line to the front side of the bell housing of the transmission to the part with the nipple on it. Check the lines for fluid leak, if not its same principle as bleeding your brake system, just do it a total of about 10 times, with the car off. Keep an eye on your fluid level in the master cylinder reservoir. Good luck, my buddy had an issue with his sticking and being spongy, and after about 30 mins of bleedin it, it was firm again.
alcatrez
Lancer Troubleshooting
Mar 23, 2016 10:55 AM
