1/4 question
Old Jan 18, 2004 | 03:09 AM
Ender2664's Avatar
1/4 question
So my friend got his sti sponsered and they have a sick evo at this shop. Here are the mods
1)catback
2)downpipe
3)intercooler houses
4)smaller battery
5)hks cams
6)boost controller
7)valves
8)intake
They have the some other stuff, but not much more than that...it has a stock fuel system, stock turbo, and stock intercooler, everything else is moded. But anyways the are running 26psi, cause they said they dont care if they blow the motor. Regardless, they also said that the car cant run 12s!!!!!!! With these mods on some 93 gas shouldnt the car be good for mid 12s? Cause they said that it is still a low 13.
Anyways the really cool thing is i bet them $500 that i could pull a 12.99 or lower in my friends STI. And the great thing is the STI has up pipe, down pipe, exhaust, grounding kit, intake, and a boost controller locked at 1.2bar. That will be the eaiset 500 that i have ever made in my life. The track that we are going to run at is at 0 elevation.
But the original question....with those mods on a EVO shouldnt 12s be a reality?
Old Jan 18, 2004 | 07:34 AM
bluevilevo8's Avatar
If those are really the mods, and they can't break 12's, then something is seriously amiss. That car should be good for low 12's to high 11's with a good tune and a competent driver.
Old Jan 18, 2004 | 11:19 AM
Fourdoor's Avatar
The problem is they are running 26 psi of boost! They have extremely hot air going into the engine because they are running the turbo WAY out of it's efficiancy range, getting knock, and having the ECU pull timing due to the knock. If they havn't already destroyed the ring lands (quite possible) they will run a much faster time (mid to low 12's) by turning the boost down to 21 psi.
I would have your friend get his STi away from that place as fast as he can get it moving, they obviously have no clue WTF they are doing.
Keith
Old Jan 18, 2004 | 11:23 AM
Quickshift's Avatar
Ya no doubt , the stock turbo is on efficent up to 23psi max. 26 is just crazy no matter what other mods they have going to it. 12.2-12.5 should be about what that car is running.
Old Jan 18, 2004 | 02:28 PM
darkturbo's Avatar
REally we can run 23 psi?? thats crazy...I did know a guy running 28 on hs and pulling 12s but that was up here in colorado. I think he probably has blow up his car by now.
Old Jan 18, 2004 | 02:45 PM
Ender2664's Avatar
Thankyou for the advice.
Old Jan 18, 2004 | 02:53 PM
Jaxice's Avatar
How does your friends STI have an Up Pipe?? Only wrx's do, due to the fact it has 3 cats...sti only has two...just wonderin heh
Old Jan 18, 2004 | 02:54 PM
rACerS's Avatar
It should be able to run high 11's.
Old Jan 18, 2004 | 02:58 PM
Ryanmcd3's Avatar
In Timeout
Sounds like the shop is a bunch of dumbass or you are full of ****. Anyone have a quarter to flip?
Old Jan 19, 2004 | 11:57 AM
Ender2664's Avatar
Actually both wrxs and stis have up pipes, it is just that the sti doesnt have a cat in the up pipe...the mod doesnt give that much horsepower cause it is only a little bigger, but it makes the engine sound alot meaner.
fromWRXtoEVO
30
Dec 27, 2014 08:19 AM
Darius@AMS
Feb 4, 2009 07:45 PM
Vostok 7
Jun 27, 2008 12:27 PM
highvoltz
For Sale - Cars For Sale
Feb 24, 2007 11:25 AM
Ender2664
Jan 2, 2004 06:28 AM
