Turbo gurus
Old Feb 22, 2012 | 09:17 PM
J!n K@z@mA's Avatar
Turbo gurus
Is it possible to remove the j pipe for the evo 9 without removing the entire turbo?
I was trying to install a new J pipe this morning but I had no luck due to space around it and time limitation. I only had 3 hrs to work on the car and I did not accomplish it.
I also want to know the size of the bolt. is it 11, 12 or 13? When I was trying to squeeze the tool i can't seem to catch the edges.
Old Feb 22, 2012 | 10:34 PM
evotuner04's Avatar
15 Year MemberLikedLoved
should be able to, is it on a lift or on some jack stands?
Old Feb 22, 2012 | 11:06 PM
Piro Fyre's Avatar
It might be 12mm and it is possible. You would need a 3/8" socket, extension and ratchet get get the job done.
Old Feb 22, 2012 | 11:55 PM
Hendrixmx's Avatar
I did mine using an extension and a swivel joint.
Old Feb 23, 2012 | 03:14 AM
J!n K@z@mA's Avatar
thanks I just want to know it it is possible before I force it and end up messing it up and not be able to go to work
beasters
Nov 6, 2014 09:26 AM
RdS
Dec 20, 2012 10:24 AM
EvoRinga
Mar 12, 2012 07:39 PM
evocivicmarc88
Nov 27, 2011 11:47 AM
bentley1
Mar 14, 2011 03:05 PM
