gcs s2 cams
Old Feb 29, 2012 | 11:24 PM
tzoyi's Avatar
gcs s2 cams
hello,if i put in my engine gsc s2 without springs and retainers,i will have a problem? i will work at 1.8-1.9 bar,and i dont know the redline,maybe 7900-8000..i have a built 2.0l and gt3076...
Old Mar 1, 2012 | 01:18 AM
tscompusa's Avatar
I would install springs & retainers. they arent exactly small cams. you risk valve float at higher rpm.
Old Mar 1, 2012 | 04:14 AM
211Ratsbud's Avatar
Without looking to be sure im nearly positive gsc specifically states the operating conditions for these cams on stock springs
Old Mar 1, 2012 | 04:22 AM
Dmav1989's Avatar
No that's the s1..it says on their site they suggest spring with the cams unless u are gonna be on factory boost levels
http://www.power-division.com/produc...cat=285&page=1
Old Mar 1, 2012 | 04:23 AM
SDevo13's Avatar
Yes, you have to do springs and retainers. I don't know why you wouldn't anyway...stock valvesprings are going to float at high power levels regardless of cams...
Old Mar 1, 2012 | 05:01 AM
todd6027's Avatar
if you rev over 7200rpm you need valve springs
Old Mar 1, 2012 | 07:58 AM
bubba17's Avatar
if your going to do it do it right! replace the valve sping and retainers. saves you trouble down the road. and yes you have to replace them with the s2's with the s1's no you can run the stockers
Old Mar 1, 2012 | 09:32 AM
Broham's Avatar
Retainers are not needed as there is no proven breakage of retainers. Springs on the other hand are highly recommended with s2's. valvefloat avoidance. S3's require retainers though.
Old Mar 1, 2012 | 04:34 PM
tzoyi's Avatar
ok,thank you guys..
4G63_Crazy
Jul 24, 2017 04:02 AM
e_kobz
Dec 7, 2016 04:37 AM
silverflyer
Nov 20, 2016 04:06 PM
seven10
May 5, 2016 05:45 PM
Dannievo
17
Sep 9, 2008 01:08 PM
