Not getting a Spark on 05 Evo 8.
Old Apr 29, 2012 | 02:15 PM
meckert's Avatar
replace the fuse-- regardless if it looks ok.. and try that.
Old Apr 30, 2012 | 03:04 PM
derangedazn's Avatar
Will give that a shot. Thanks.
Right not checking fuel. Walbro whine does not come on when the car is on the "on" position.
Old May 3, 2012 | 12:50 PM
daimanpancholi's Avatar
Hi, i also have the same problem,
I have a evo 7, i have checked all relays and fuse´s.
The engine cranks, all electics works, but will not start!
There is no spark and the fuel pump is not kicking in, i have checked the fuel pump and that works fine.
I´m thinking to get a crank angle sensor? but not sure if it is that.
I know the feeling
let me know if you get yours sorted or if i get mine done before you i´ll let you know.
cheers
Old Jun 3, 2012 | 08:36 AM
Update:
Replaced spark Plugs
Fuses checked
Replace crank position angle sensor
Replace Cam Angle sensor
Removed Silencer Security Alarm
Ran Evoscan: Fuel Pump activates
Crank Signal goes from 0-1 when trying to start.
Battery charge
Engine cranks but will not start.
TheMowerman
Apr 13, 2016 05:59 AM
kawarob78
12
Jul 1, 2014 01:32 PM
Kiartiger
Feb 8, 2014 10:54 PM
iwantevonow
Jan 10, 2011 10:43 AM
OneEyedJack
47
Sep 9, 2010 07:30 AM
