What's this part?
Old Mar 20, 2012 | 06:04 AM
snafufx's Avatar
What's this part?
So.....finally completed my throwout bearing replacement for the first time and notice a cyclinder "shaft" or something. I recall seeing that same exact part when I sent my shep trans to get rebuilt almost 7 months ago and the package included this part and have no clue what it is for. Attached is the old one which I found just chillin on top of my trans once I was complete. Any idea what it is and does it have to be installed and where in the world does it go? Shep sent two of these shaft things. I checked every connection, thinking it slid into one of the holes connecting the transfer case to the trans, but couldn't fit it. Thanks.
Measurement wise, it's maybe 3/4" long, 1/2" wide
Old Mar 20, 2012 | 06:15 AM
mcm308's Avatar
Im looking at small pics on my phone but looks like the locator/dowel used to locate the transmission bellhousing to engine block. 2 of these are usually on the block side and when you install tranny..
Old Mar 20, 2012 | 06:20 AM
snafufx's Avatar
Jesus, do they have to be installed or would not running without one cause any trouble because damn if I plan to rip this out again anytime soon. It does look like a metal dowel though. Thanks
Old Mar 20, 2012 | 06:31 AM
BoostINurI's Avatar
So do you have one or none on either mating side of trans or block?
Old Mar 20, 2012 | 06:37 AM
snafufx's Avatar
I have one, and in order to install the other I do I have to drop the trans again or could I simply unbolt whichever spot it is and slide it in?
Old Mar 20, 2012 | 06:38 AM
n2oiroc's Avatar
They need to be there to line it all up. If its out you can wear or break clutch parts or the input shaft.
Old Mar 20, 2012 | 07:05 AM
snafufx's Avatar
So the final question, where are these two dowels suppose to go exactly? I recall 3 bolts at the top, one bolt towards the rear that actually connects to the block itself. Do I have to drop the entire trans again or something else?
Old Mar 20, 2012 | 08:27 AM
BoostINurI's Avatar
When you take trans back off look at the mating side....look at the bolt holes an youll see a sleeved area around the bolt hole....thats were they go....gl
Old Mar 20, 2012 | 08:48 AM
snafufx's Avatar
Thanks, luckily I have a friend able to come over Friday to help with this. If I can muster enough strength I *might* start ripping everything back out...for the third time. I really need a new DD, ever since I upped my power, seems like it's always down, god knows what it'll do when I toss in the BB Black when I get it....
Old Mar 20, 2012 | 02:23 PM
BoostINurI's Avatar
Live and learn man....you should invest in a dd....youll make power when the black is on!
snafufx
Dec 5, 2013 03:34 PM
snafufx
Mar 11, 2013 12:39 AM
snafufx
Jul 21, 2012 12:06 AM
snafufx
41
Apr 17, 2012 02:07 PM
snafufx
Mar 18, 2012 04:52 PM
