Torque Solutions underhood shift bushings
For those that installed the Torque Solutions ones, did you re-use the stock washer?
When I look up the how to for the Kartboy poly ones or the AMS/Speed Source/Buschur metal ones they say to re-use it, was wondering if the Torque Solutions were any different? (They feel like nylon/delrin...dont know if that changes the process)
TS lists the Delrin on their website under Shifter Cable bushings, and the aluminum under Shifter Base bushings
http://www.torquesolution.com/Mitsub...ts-scb-200.htm
http://www.torquesolution.com/Mitsub.../ts-bb-004.htm
So which is under hood and which is under the center consol?
I just picked these up from AWD Motorsports. They look good and I will be installing this weeked
Can I still use lithium grease or PB blaster to oil up the Delrin materila under hood bushings?????????
sammyrex
Apr 11, 2015 05:40 AM
belizelittle39439
55
Jan 28, 2011 10:15 AM
