How to adjust TPS?
Old Apr 15, 2012 | 10:19 PM
jameswwt's Avatar
How to adjust TPS?
How to adjust TPS value as near to 100%? Can it be adjusted via laptop during ecuflash or evoscan?
Or ive to manually turn the tps sensor near the T/B and can a multi meter tell if the value is 100% when full pedal without starting the engine as just the ignition On?
What is the voltage figure on a 97~100% Tps?
Thanks
Old Apr 16, 2012 | 01:02 AM
blknblubkrdude's Avatar
Key on, engine off.
Evoscan or Code Reader/Scanner that is data capable
Loosen both TPS bolts (6mm or 7mm)
Open throttle plate all the way by hand
Turn TPS until you are as close to 100% as possible
Tighten bolts
Good luck!
Old Apr 16, 2012 | 01:43 AM
jameswwt's Avatar
Originally Posted by blknblubkrdude
Key on, engine off.
Tighten bolts
Good luck!
Thank you so much..
Old Apr 16, 2012 | 05:52 PM
JohnBradley's Avatar
actually set it at 13.33 at idle and its good. WAY easier.
Old Apr 16, 2012 | 06:18 PM
I originally thought that, but I have since seen a couple vehicles that 13.33 equates to somewhere in the 96-97% range. But if 13.33 works, that's the way to go!
Old Apr 16, 2012 | 06:24 PM
If they are 96-97% there is something else wrong or a non factory throttle body. Factory is 13.33%.
Old Apr 16, 2012 | 06:43 PM
jameswwt's Avatar
My current reading is :
Car off ignition Off : 9.0196
Car off ignition On but full pedal : 92.157
Will a slight inaccurate tps figure affect the tuning performance or car response performance?
Thanks
Old Apr 24, 2012 | 08:28 AM
jameswwt's Avatar
Hi, will a low reading TPS % affect the car overall response?
kamote2000
Mar 8, 2017 12:30 AM
jb988
Jul 4, 2016 06:30 PM
Dvolution
Jan 14, 2014 03:29 PM
SLYDOGRACING
Aug 9, 2010 03:42 PM
utripin
Feb 17, 2010 09:52 PM
