quaition on new 6466 vs 6766 .
Old Apr 30, 2012 | 07:10 PM
SmurfZilla's Avatar
I made more the 735 on a 6265. I would've made over 800 if one of my fuel pumps didn't become an issue.
I'm sure the 6266 can hit 850. It'll be in its upper ranges. but it should be able to achieve it.
Old Apr 30, 2012 | 07:56 PM
maperformance's Avatar
Originally Posted by asubennett
You misnterpreted what I was getting at. Sorry I should have been more clear.
If the 6466 has made a witnessed 950whp on a dynojet I would think the difference between the 6266 and 6466 would only be 100hp at best for the mechanical difference bewteen the two turbos.
I have yet to see a 850whp 6266 graph. Have you? If there is a 6466 graph at 950whp dyno jet it makes me optimistic that a 6266 could crank out 850whp dynojet on kill in a well equipped set up.
The 6466 has a different blade profile, which obviously has proved to be the better over the latter designs. Thus why it can make as much power as the 6766, and be a little smaller.
Old Apr 30, 2012 | 07:59 PM
It would be out of its efficiency range and would be dumb to push to that point.
If you want 725+whp turbo, get the 6466. If you want 1000whp get 71HPSHP.
Old Apr 30, 2012 | 08:04 PM
PRS's Avatar
PRS
The 6466 looks to be a beast
Old Apr 30, 2012 | 08:28 PM
EvoDan2004's Avatar
i would hope PTE would take that 6466 7 blade compressor technology and make it into a 7 blade 67mm for the 6766. that might do well too.
Old Apr 30, 2012 | 10:55 PM
I'm sure there is a reason why they haven't. Might not be efficient in that size, just like we use different wheels in our EVO X turbo's than our EVO 8/9 turbo's and not just because of reverse rotation.
Old May 2, 2012 | 12:59 PM
EVO(boss)'s Avatar
I ordered 6466 from u adam and I will see .
Old May 2, 2012 | 01:04 PM
You'll be happy, I promise. As I promise EVERYTHING
Old May 2, 2012 | 01:06 PM
EVO(boss)'s Avatar
thanks man I trust u 4ever
Old May 2, 2012 | 03:52 PM
Svendiesel's Avatar
DAMN the 64 is like $700 bucks more than the 67.
Old May 2, 2012 | 05:09 PM
JohnBradley's Avatar
Just got done Etuning a 6466 that is at the track at 37psi dropping to 33 on a 2.4 VIII. 26psi by 4600, ran a 6.7@111 spinning, unknown vehicle weight.
Old May 2, 2012 | 06:40 PM
EvoDan2004's Avatar
is that good? sorry im not being sarcastic. i just dont know.
Old May 3, 2012 | 04:09 AM
SmurfZilla's Avatar
I'm making 777 at 33 PSI on the 6265 and I'm not pushing the turbo I use now. I don't know how the 6266 would be any less efficient.
Old May 3, 2012 | 09:02 AM
Umm, no its not.... Its cheaper than the 67....
Old May 3, 2012 | 09:05 AM
Like I said if you want 725+ get the 6466. 6266 efficiency range is 735whp, once you hit that PTE themselves recommend the next up turbo, which is the 6466.
