quaition on new 6466 vs 6766 .
Old Apr 20, 2012 | 05:54 AM
EVO(boss)'s Avatar
hi guys
I need to know which turbos would make a high power on pump and race gas ? 6466 or 6766 ? the engine is 4G64 2.1L .
the turbo kit is twin scroll T4 MAP turbo kit
thanks
Old Apr 23, 2012 | 05:52 AM
PrimerSdime's Avatar
Both turbochargers are going to make high power on pump and race gas. What are your goals with this setup?
Old Apr 23, 2012 | 06:00 AM
EVO(boss)'s Avatar
850whp on 40-45psi .. my setup is : MAP satge2 4G64 2.1L o-ring , AMS CNC head , MAP twin scroll T4 turbo kit ( 6466 or 6766 ) twin DW300s in tank , 2150cc , and alot ..
Old Apr 23, 2012 | 09:02 AM
talonspyder97's Avatar
There hasn't been much testing that I know of with the 6466 but it does look promising. I would wait a couple of weeks to see what is released from PTE as far as who tested it and there results.
-Adam
Old Apr 25, 2012 | 12:24 AM
EVO(boss)'s Avatar
yah that why I'm still waiting , but I think the 6766 is the best for really high power .
Old Apr 25, 2012 | 12:32 AM
EvoDan2004's Avatar
Both turbos maxed out the 6766 will make more. The 6466 will be close but will not make the peak number the 6766 will but will have a better power curve
Old Apr 30, 2012 | 11:23 AM
maperformance's Avatar
Both turbo's are rated for the same horsepower. I have seen 50psi on both turbo's make 950whp.
Old Apr 30, 2012 | 12:40 PM
asubennett's Avatar
Wow. What is the most you have seen out of a 6266. I cant believe 6266 to 6466 people are seeing 200HP. I would think more like 100whp for the change but I have yet to see a 850whp 6266 graph.
Old Apr 30, 2012 | 04:21 PM
Nobody said there was a 850whp 6266 graph?
Old Apr 30, 2012 | 04:47 PM
EvoDan2004's Avatar
PTE says a 6266 was 735 and the 6466 is 900.
6266
http://www.precisionturbo.net/Street...PT6266-CEA/479
6466
http://www.precisionturbo.net/Street...PT6466-CEA/494
Old Apr 30, 2012 | 05:06 PM
Originally Posted by evodan2004
Correct, however @50psi the 6466 has made 950whp+
Old Apr 30, 2012 | 05:08 PM
EvoDan2004's Avatar
maybe i am confused. you said the 6266 and 6466 are rated the same. or did you mean the 6766/6466
to many dam 6's in this thread.
Old Apr 30, 2012 | 05:29 PM
jmcmill3's Avatar
he said 6466 and 6766 but in your defense, yes, alot of 6's
Old Apr 30, 2012 | 05:36 PM
asubennett's Avatar
You misnterpreted what I was getting at. Sorry I should have been more clear.
If the 6466 has made a witnessed 950whp on a dynojet I would think the difference between the 6266 and 6466 would only be 100hp at best for the mechanical difference bewteen the two turbos.
I have yet to see a 850whp 6266 graph. Have you? If there is a 6466 graph at 950whp dyno jet it makes me optimistic that a 6266 could crank out 850whp dynojet on kill in a well equipped set up.
Old Apr 30, 2012 | 05:55 PM
EvoDan2004's Avatar
Ok then I am sorry. thanks for clearing that up
