ACD & transfer case oil
Old Apr 23, 2012 | 09:23 AM
tmaddox's Avatar
The manual says use LSD oil for the "transfer case" and "rear differential" and use Diamond ATF SPIII for the "active center differential"
Isn't the ACD the same as the transfer case on a Evo 8 2005?
Old Apr 23, 2012 | 10:03 AM
gsrboi80's Avatar
No the TC and rear Diff take Diaqueen LSD Gear Oil ONLY. the ACD fluid "Diamond ATF SPIII" goes in the reservoir under the hood drivers side front of car
Old Apr 23, 2012 | 10:08 AM
tmaddox's Avatar
Thanks - I'm one of those newbies that always has a ? over his head in the cartoons.
I was thinking a center diff was the same as a transfer case, therefore I thought the ACD was the transfer case. Too many years working on a 1975 chevy blazer.
Old Apr 24, 2012 | 05:39 AM
tmaddox's Avatar
Does anyone ever change out the ACD fluid, or just transmission, diff and transfer case? And how would you change it, same way as flushing a power steering pump?
Skidonner90
Jul 20, 2016 07:49 PM
amsevokid
Nov 30, 2015 03:39 PM
A3188
13
Apr 14, 2014 04:32 PM
hahnsolo
Jun 22, 2010 08:53 PM
Evo3GEclipse
11
Jun 14, 2007 11:00 AM
