Long Rod vs Short Rod
Old Jul 3, 2012 | 11:36 AM
  #31
spdracerut's Avatar
Some more info on going to a longer rod:
http://www.motoiq.com/magazine_artic...part-deux.aspx
Old Jul 4, 2012 | 03:22 AM
  #32
GSR ONE's Avatar
Originally Posted by KGB_KGB
I am building a short block with 150mm and 94mm crank.
AMS drag evo users them, and I guess it should be as good as a long rod.
Any inputs
All depends on preference and application if your a DD the 2.3 or 2.4 seem to be the way to go, has more displacement and torque in the lower RPM range.
Go to Buschur Racing, he's got some good points about choosing the right engine for your application. Here's a link.
http://highboostforum.com/forum/show...for-your-build
Old Jul 7, 2012 | 09:10 PM
  #33
masonh's Avatar
Basically the LR motor is a better choice.
i don't know if that could be stated as fact or not after reading this thread.it seems in some opinions the gains of the LR are minimal at best.
Old Aug 10, 2012 | 06:10 PM
  #34
bader's Avatar
What pistons are you guys using for your lr builds (part number) I looked through the wiesco catalog and didn't really see what I wanted for the 87mm pistons. What about higher comp pistons to with the longer dwel time sounds like it could be bad
Old Aug 11, 2012 | 03:23 AM
  #35
GSR ONE's Avatar
2.3l stroker pistons (Wiseco - K596M85). JAM use Venolia which can be custom made but cost a little more. IMO I'd stick to 86mm bore.
Old Aug 11, 2012 | 08:11 AM
  #36
bader's Avatar
I thought the 2.4 was 86.5 STD are you sleeving them instead of going. 020 over
Posted from Evolutionm.net App for Android
Old Aug 11, 2012 | 11:55 PM
  #37
GSR ONE's Avatar
If your going with the 4g64 2.4l thats fine. On the 4g63 block I'd stick with .040 over.
burnzy
Jul 21, 2016 07:35 AM
Lombardi23
May 27, 2016 11:30 PM
railgunner50
14
Jul 25, 2013 09:41 AM
94AWDcoupe
26
Oct 26, 2010 12:21 PM
