No start after walbro install
Old May 5, 2012 | 11:48 PM
SWOLN's Avatar
Ultimately, I had to get a new seal to fix mine... What i mean by push it down is. Do no force the grommet onto the pump.
Old May 5, 2012 | 11:58 PM
AWDs's Avatar
Originally Posted by utripin
Is there fuel at the rail? Do you have a fuel gauge? Really need to know if your fuel pressure is right...33 is stock..after market FPR..42 to 45 Psi. There is a o-ring in the fuel sending uint...the white thing that houses the fuel pump. Did you take the black plug with the connected ground wire to it out? If so the o-ring may not be seated. If it isn't you won't have pressure to start/run the car. re-track your work...take the sending uint back out and have a look at things. Good luck!
Thanks for the reply, I don't have a gauge, if I pull the return line at the rail it's dry. I took the black plug with the single ground wire out is there an o-ring that sits in that section? It might have fallen out, and I didn't know one belonged there. I really hope that's my problem. I thought the only seal was at the top of the pump.
Old May 5, 2012 | 11:59 PM
AWDs's Avatar
Ok thanks I'll try that again, and double check the grommet.
Old May 6, 2012 | 07:09 AM
blknblubkrdude's Avatar
Yes, just disconnect the small hose feeding back into the fuel pump module, and crank it.
I have had this happen several times to my Evo, as well as many cars when working as a GM technician.
Old May 6, 2012 | 07:39 AM
240Z TwinTurbo's Avatar
Originally Posted by AWDs
Ok made sure it's seated, and it's perfect. The only time I can even hear the pump is at the end of cranking. I can't hear the relays clicking either.
Just to make sure, you have to seat the rubber grommet onto that connector and then insert back to the pump housing. You cannot leave the rubber grommet in the pump housing and then insert the connector. Again, this is not part of the actual pump and I think it is part of the clip at the bottom right of the pic.
Old May 6, 2012 | 08:09 AM
nytalonTSi's Avatar
The isolator piece that fits under the plastic retainer?
Old May 6, 2012 | 02:21 PM
AWDs's Avatar
Success. The rubber o ring must have fallen out of the ground connector at the bottom of the pump, and I didnt realize it. Thanks to everyone who helped me.
Old May 6, 2012 | 02:45 PM
byt's Avatar
byt
Nice, glad you got it running
Old May 6, 2012 | 05:57 PM
That clip right below my thumb in the pic. I am not sure what the sensor does, but if removed you must make sure the rubber grommet is put onto the sensor first before reinserting. If this doesn't seal you can get fuel pressure, which was the OPS issue.
Old May 7, 2012 | 12:03 AM
utripin's Avatar
I thought that was what it was.....glad you goody fixed.
Old May 7, 2012 | 01:26 PM
xtruemassacre's Avatar
it needs to be "primed". put a couple gallons of gas in the car if its empty or near empty. may as well fill it;
Fast_Freddie
33
May 29, 2013 11:27 PM
joseph143
Oct 25, 2012 05:00 AM
alexso15
Aug 21, 2011 11:17 AM
jdmtrav
Mar 17, 2011 10:32 AM
ctdragon
10
Mar 6, 2005 06:19 PM
