Max power on FIC1100s running E85?
Old May 10, 2012 | 08:15 AM
mrfred's Avatar
My FIC1100s appear to be going static (100% IDC) right as I cross 500 whp on E85 that's 82% ethanol. Wondering if anyone else has experience with maxing out these injectors.
Old May 10, 2012 | 08:26 AM
Spec-Ops1's Avatar
I haven't maxed out a set of the FIC 1100s as most people are on stock turbos still... However I did max out ID1000s at around 475HP on E85, single rewired & modded 255, this was on oem FPR, so base pressure was around 56 psi...
Old May 10, 2012 | 08:51 AM
scheides's Avatar
EvoM Moderator
Even with the W400 in there?
Sounds about right, lots of local guys max out PTE1000's on a single walbro 255 around 500whp...I'd think with the w400 you would have a bit more headroom though
Old May 10, 2012 | 09:05 AM
TheBoz's Avatar
I am right about 450whp, and at 90-92% DC on mine. I was going to do a double pumper and a AFPR and bump the base to like 60psi, to extend the output.
Old May 10, 2012 | 09:23 AM
mrfred's Avatar
From the posts so far, it sounds like 500 whp is about right for a 1000 cc/min injector on E85. Between the W400 and my -6 AN hose supply line, there's plenty of fuel for the stock fpr to maintain a net fuel pressure of 43.5 psi across the injectors, so my setup is a best case scenario for the stock fpr. I'm contemplating doing what TheBoz did and increasing my baseline pressure to 55 psi. That should be enough for 560 whp. Or I might buy a set of FIC1250s and sell my FIC1100s. I sure would like to stay on a high-Z injector though...
Old May 10, 2012 | 10:16 AM
scheides's Avatar
EvoM Moderator
1250's is probably the right way to go, don't get too tied to the high-z injectors....they 1250's will do dandy
Old May 10, 2012 | 10:40 AM
Levar's Avatar
Veteran: Army
I thought there was an issue with the FIC 1250s, no? This was why I selected the FIC 1450s. This is very interesting.
Old May 10, 2012 | 11:10 AM
mrfred's Avatar
1250s and 1450s are in the same family. No prob with them. The FIC1680s which are in a different family of injector were a problem though.
Old May 10, 2012 | 12:26 PM
Levar's Avatar
Veteran: Army
I see. Thanks for teaching me.
dkorr
Oct 24, 2015 12:28 PM
JohnBradley
Sep 30, 2015 02:54 PM
JohnBradley
Jul 8, 2015 05:51 PM
FathouseFab
Evo X Dyno Results
28
Feb 15, 2014 02:04 PM
ToFastforU_99
Evo X Dyno Results
60
Apr 5, 2011 09:45 PM
