killing thrust bearings in turbos
Old May 17, 2012 | 05:08 PM
evoix16's Avatar
anyone else have this issue, ive killed 3 turbo's all t3 or t4 frame turbos, im running the oil feed from the head. thinking about switching the oil feed to the oil filter housing. no side to side play or up and down. Only in and out play. any ideas i thought it could be the 2 step killing them but unsure. feel free to post any ideas as to the cause
Old May 17, 2012 | 05:13 PM
n2oiroc's Avatar
Precision journal bearing turbos?
Old May 17, 2012 | 05:16 PM
evoix16's Avatar
2 of them the other was a garrett gt4088 also journal but was rebuilt by a legit shop
Old May 17, 2012 | 05:31 PM
ExViTermini's Avatar
Ever logged oil pressure?
Old May 17, 2012 | 05:40 PM
sparky's Avatar
What oil were you running? Is this with the stock oil pan? If stock pan, are you running the factory recommended amount of motor oil?
Old May 17, 2012 | 05:42 PM
sparky's Avatar
I had some bearing issues with Precision in the past, too.
Old May 17, 2012 | 05:43 PM
evoix16's Avatar
factory oil pan and i always went by the dipstick level and ran a lil above full
Old May 17, 2012 | 05:45 PM
evoix16's Avatar
i ran mobile 1 10-40 i live in florida it gets pretty hot, also my engine is built and no balance shafts
Old May 17, 2012 | 05:46 PM
evoix16's Avatar
didnt have a oil pressure gauge at the time and if it shows up in mitsu log my tuner didnt see an issue with my oil pressure
Old May 17, 2012 | 05:49 PM
Vivid Racing's Avatar
Did you log oil pressures? Sounds like your turbos aren't getting enough oil.
Old May 17, 2012 | 05:54 PM
evoix16's Avatar
i had no way of logging oil pressure at the time, my engine is currently apart for upgrades
Old May 17, 2012 | 06:32 PM
ScorpionT's Avatar
Sounds like a lack of oil pressure. Be sure to check that when the motor is back together.
Old May 17, 2012 | 06:34 PM
evoix16's Avatar
i will i just have to buy a pressure sensor for my zeitronix
Old May 17, 2012 | 06:37 PM
See what the motor looks like when it's apart. IE, pull a rod cap
Old May 17, 2012 | 06:43 PM
evoix16's Avatar
rod bearings were fine
