Question for all Engine builders
Old May 22, 2012 | 05:45 PM
domestickillaAR's Avatar
I know everyone has their fav parts they like to use this question is in reguards to Rod and main bearings.. Now most people ive talked to swear by ACL or Clevite, but ive really had my eyes on trying some King Bearings and ordering them with the optional ceramic coating.
http://www.maperformance.com/king-ma...s-dsm-evo.html
Has anyone used this and what kind of results did you see from them? what was your motor combination and HP output?
my motor is a 2.0L aluminum rod 9.1 comp motor, WHP should be in the 730-750 area. Im doing everything i can think of to make my combination as efficent as possible esp by reducing friction where i can. im going to be using an ESP armor coated eagle crank also for this very reason and was wondering if these main and rod bearings would be a good match ?
Old May 22, 2012 | 07:15 PM
n2oiroc's Avatar
king makes great bearings. are you sure its a ceramic coating? ceramic is much harder than steel and would be a terrible surface for the crank to mate with. you want the bearings to be softer than the crank.
Old May 22, 2012 | 07:34 PM
according to the Drop down link bar on MAP's website its a Ceramic Coating. goto the link i posted and youll see what im talkin about
Old May 22, 2012 | 08:22 PM
mt057's Avatar
It mentions on the site on the drop down that it is a dry film lubricant.
Old May 22, 2012 | 08:28 PM
guess its both lol
Do you want lowered friction and more galling protection from your bearings? Then our advanced dry film lubricant ceramic coating is what you need. This coating will not need any changes to clearances as it bonds at 20 millionths of an inch or can be buffed to a "0" tolerance while still retaining it's properties. This coating will greatly reduce power robbing friction and actively retain oil films even after sitting for months or being oil starved in high-g racing to minimize the chances of a galled bearing. A must have for anyone looking for safety and longevity in their bottom end.
Old May 22, 2012 | 08:29 PM
has anyone or any shop had experiance with these bearings? my main concern is esp since im building an Aluminum rod motor would these be my best choice?
again im wanting to reduce as much friction in the rotating assembly that i can and also hope i get the most run time out of the engine possible
Old May 23, 2012 | 07:54 AM
ChrisCarey's Avatar
We've used both ACL Race and King XP bearings in our race engines without issue, can't go wrong either way.
Old May 23, 2012 | 06:19 PM
thank you for your input Chris
Old May 25, 2012 | 06:47 PM
n2oiroc's Avatar
a guy on the subaru forum had a lot of trouble with the dimensions of acl's (as did many others). he bought a box of kings, and they were very consistent. something to consider.
Old May 25, 2012 | 09:35 PM
thanks for your input ..yeah thats def something very important to keep all the tolerances the same. did he Mic all the once he had and keep sending back the ones that were mismatched?
My03evo
19
Nov 14, 2024 10:08 AM
kaj
22
Jan 27, 2019 12:23 AM
roni4g63
Oct 28, 2016 01:43 AM
dsmerjosh
Jun 9, 2015 04:57 PM
My03evo
May 15, 2011 01:37 AM
