Quick bearing question
Old May 13, 2011 | 11:37 PM
My03evo's Avatar
Question Quick bearing question
I'm ordering bearings, I deff want the +.001 clearance bearings for the rods, but should I get them for the mains too? or it's only necessary for the rods because they take more abuse..?
Thanks
Old May 14, 2011 | 03:38 PM
My03evo's Avatar
Is this thing on?
Old May 14, 2011 | 07:14 PM
barneyb's Avatar
Are you overhauling your engine or what?
Old May 15, 2011 | 01:37 AM
My03evo's Avatar
Nah engine has 7k miles on it, recently had the engine/trans/tc out for other reasons, after getting it together again I started hearing a knocking sound getting louder and louder.From BARELY noticeable to noticeable anytime under load. Rod bearings werent BAD but werent good, and they (3 of the 4) had very weak "crush" I could push them in the caps with no effort, where as the new ones are tight as should be. But I'm changing all the bearings and don't know if I should get the .001+ bearings for the mains and rods, or just the rods. Engine is in the 550hp+ category. As far as the reason it started knocking I'm blaming it on only running 10w30 which is my fault because I didnt know it had the looser bearings since I got this engine in the car when I got it. I was running Rotella T6 5w40 for most of the time but put shell T3 10w30 in it to "rinse" the engine out since I had the pan and head/cams off since its cheap oil. Now will be running the new Amsoil Z-rod high zinc 20w50 now that I know about the bearings.
I currently have the .001 race bearings for the main And rods....I think they are normally only used in the rods but thats why I made this thread and been searching. The mains in it now dont help me since I can't find the p/n ANYWHERE online to tell me what size/make they are. I think its D6J C...I plan on plastigauging mains and rods so I have an idea what the clearances will be so I can go from there.
Are these bearings primarily for use in the rods and mains or just the rods?
2006GSR
Mar 11, 2016 08:54 AM
Dannievo
16
Apr 26, 2015 08:54 PM
ryans1000
26
Mar 5, 2014 07:20 PM
evoboy2006
16
Mar 7, 2012 08:31 PM
SOEuro
Jul 16, 2010 12:42 PM
