ETS 3.5 IC Wide Tank fitment problems
Old May 25, 2012 | 01:48 PM
asu11's Avatar
Well got around to installing my IC and am having a problem. The 2 bolts holes where the front bumper bolts too in the front by the 2 ic holes are being bent by the IC not letting me put those 2 screws in. Anyway around this?
Old May 25, 2012 | 02:18 PM
RJones's Avatar
I just cut those tabs off when I installed my ETS fmic. They were already in the way of my splitter mounts, so the bolts weren't in anyway. You don't need them. The four attachment points up top and two in the wheel well, along with the clips should be good. I race my car and haven't had any issues with it.
Old May 25, 2012 | 02:20 PM
STLEVOIX's Avatar
Instructions say to zip tie them
Old May 25, 2012 | 02:24 PM
asu11's Avatar
Hmm might do this.
asu11's Avatar
Zip tie what?
Old May 25, 2012 | 03:18 PM
ETS Michael's Avatar
I'm not sure what he is referring to with the zip tie. We don't use zip ties on anything. I don't recall any cutting on the cover, just the lower grill bracket area, but that's with any front mount intercooler. I would most likely trim them like RJones suggested.
Michael
Old May 25, 2012 | 05:16 PM
asu11's Avatar
Michael
Will try bending the ic mounts tomorrow to try and straighten them out. Also going to cut the tabs for the front mounting bolts off. I assume noone has any problems not using them? What trimming of the lower grill are you referring to?
Old May 25, 2012 | 05:25 PM
evotuner04's Avatar
15 Year MemberLikedLoved
Can you post any pictures of the problem areas?
bsh
Jun 16, 2017 05:43 AM
i64X
Evo X How Tos / Installations
138
Feb 27, 2016 03:30 PM
Sti THIS
Nov 28, 2008 11:36 AM
webguy330i
35
Aug 19, 2004 06:09 PM
evilution8
Jan 31, 2004 07:20 AM
