help, what CR pistons are these ?
they are Wisecos, stamping on top of pistons says:
6596M86
2684L
they are stroker pistons but can't find in any catalog what compression ratio are these
any help would be great
6596M86
2684L
if they are off the shelf pistons a quick google search of the part # should tell you. if not you could always call them yourself. and if that fails... google CR calculator and it should give you a formula to get the CR. you will most likely need a machinist micrometer and other tools to get exact measurements of the things you need to plug into the formula, but it can be done. more than likely no one will be able to tell you the CR on here from part #'s
not that this is conclusive in any way shape or form
but that dish looks similar to the stroker pistons i had at one point...if its -12cc it will be 8.5:1 in the DSM head and 9.0:1 in the later Evo head
Mitchimus
Jul 16, 2015 03:26 AM
bmxer4it
Aug 19, 2012 07:58 PM
