New turbo setup. Where do I connect these?
Old Jul 2, 2012 | 10:03 PM
CtSilver03Evo's Avatar
Hey guys,
I just got a externally gated 35R setup. I am converting my car to speed density as well. That being said, where would I connect the vacuum line that runs from my stock boost solenoid, and where would I connect my MBC? would I connect one and of my boost controller to my external wastegate, and the other end to a vacuum tee between the boost solenoid and blow off valve? Thanks!
Old Jul 3, 2012 | 02:20 AM
GotWheelHop's Avatar
If you are asking questions like these, you probably should have a shop working on your car. That being said, the boost controller needs a dedicated boost source, not a line from the stock solenoid. Boost source/boost controller/wastegate. The BOV should have a dedicated line as well, not being teed in to another line. Best of luck.
Old Jul 3, 2012 | 10:07 AM
That's why I asked... I had my car built and configured perfectly fine before. This is an entirely new setup for me, and I'm new to speed density.
I left the lines not hooked up to anything and dropped the car off at the shop that is tuning it.
For future reference, since I like learning and don't see why my question was a huge deal, where would the factory boost solenoid connect to?
Old Jul 3, 2012 | 10:52 AM
gsrboi80's Avatar
If you're running a mbc just leave the factory boost solenoid plugged in and cap the ports off. Run line from boost source to mbc and mbc to external wg.
metallics2000
Oct 8, 2016 10:47 PM
Lanart2011
21
Mar 27, 2016 06:13 PM
4bangn
Aug 20, 2015 05:30 PM
soldave
Feb 8, 2013 03:26 AM
RyanM
Mar 23, 2007 01:51 PM
