Fluid leaking where Transfer Case and Transmission Meet
Old Jul 7, 2012 | 04:51 PM
memphis raynes's Avatar
I am getting ready to do the HG on the Evo8 I just bought a few weeks ago and car has been sitting in the garage for a couple days and noticed some leaking off the tcase (see picture). I wiped it up this morning and 12 hours later, the fluid is back. What does this look like to you guys? What would be leaking with the car just sitting there? I know there are two o-rings between the transmission and the t-case. Could these cause this? Any help would be appreciated!
This is a rebuilt Stage 3 t-case from Shep and a new rebuilt tranny from Shep as well. Was put in the car before I bought it.
Old Jul 7, 2012 | 05:09 PM
boostzealot's Avatar
Bet you one of the two seals on the t-case are either cut or got damaged during the install of the t-case. If one is not careful while mating the t-case to the tranny one of the two seals can become damaged and can allow fluid to leak. Its just a bummer that you werent there during the install so in order to check them you have to take the t-case off the tranny. Lets hope its something else so you dont have to do that. Also, if you do have to take the t-case off the tranny make sure you inspect the flanges very well to ensure they are not cracked and also make sure to torque the t-case bolts to the correct torque and not what your elbow can handle.
Old Jul 7, 2012 | 05:20 PM
Chef-j's Avatar
I have read about O ring that makes leak between there. Might wanna search, there are few threads about with good info.
Old Jul 8, 2012 | 07:10 AM
TommiM's Avatar
My vote is the o-rings as well. During install if they slide out a bit while your getting the tcase and tranny mated up it will definately cause a leak.
Old Jul 8, 2012 | 07:13 AM
TommiM's Avatar
Is that harness under your tcase the starter wire? Did you reroute that? The starter wire normally runs above the tranny down to the starter.
Old Jul 8, 2012 | 07:52 AM
thedru13's Avatar
Orings.. pull the tcase off and replace them.. Just careful when re installing. They tear easy.
Old Jul 8, 2012 | 08:22 AM
1badgsex's Avatar
def the orings i had the same prob and it looks about to be the same amount of fluid i had, shep did mine also but he forgot to put a new oring on the outside and i totally forgot to check before i installed and had to pull the t case again to put the seal in, once i did that havent had a leak since !
Old Jul 8, 2012 | 08:45 AM
Thanks guys. Not looking forward to pulling the T-Case.. but I guess I am going to have to.
Yes, that is the starter wire. The battery is relocated to the trunk.
Old Jul 8, 2012 | 09:02 AM
thedru13's Avatar
Yah man just bite the bullet sure beats paying for a rebuild... ;-)
Old Jul 8, 2012 | 12:40 PM
What fluid should I be using in the T-Case knowing that it is a Shep Stage 3 build with a QUAIFE LSD..
Also, what should I be running in the Tranny?
Old Jul 9, 2012 | 04:04 AM
way2qik's Avatar
Redline Lightweight Shockproof.
EvilDSM97
Jul 16, 2016 06:10 PM
stunna2o1
Jan 25, 2016 07:02 PM
Midnightevo8
14
Dec 31, 2015 08:02 AM
apexsilver8
Sep 13, 2012 06:58 PM
BEKevo
11
May 6, 2012 07:29 PM
