intake charge system malfunction
Old Jul 19, 2012 | 07:34 PM
Can Of Rockstar's Avatar
Ok, so the other day I was bored while driving and I started paying attention to my A/F ratio and noticed it jumps to 20.00 when i just let the car coast. So being the paranoid me i took out my phone and checked Torque for any fault codes. Im getting a gray P2263 code (intake charge system malfunction), but my car seems to be running just fine, builds boost normally and everything. Does anyone have any ideas about why its throwing that code, and where I should start my investigation? Oh and if anyone knows why my A/F ratio jumps to 20 while coasting? Thanks!!!!!
Old Jul 19, 2012 | 09:47 PM
akeric's Avatar
this is normal, on decel the car turns off the injectors because you don't need any fuel, as for the code try clearing it with evoscan or whatever you have available and see if it comes back. Also would help if we knew what mods you have, could be a problem with the maf, boost controller, map sensor maybe? boost leak?
reset code, boost leak test (always a good idea) check maf wiring, boost controller wiring, map wiring, especially if you have recently messed with any of these. Also did you have a check engine light before this? or did the code just show up when you read it?
Old Jul 20, 2012 | 03:27 AM
The only mod I have is synapse BOV, just messed with all piping from airbox to turbo and cleaned maf with electronics cleaner, so ill check for proper fitment, no check engine light,code shows up only when read, I thought it might be boost leak but I recently did a boost leak test and fixed all boost leaks
Old Jul 20, 2012 | 10:43 AM
akeric's Avatar
did you try resetting the ecu?
Old Jul 21, 2012 | 03:15 AM
No I have'nt, but good idea, ill do that, oh I forgot I also have a walboro 400 lph fuel pump
Old Jul 26, 2013 | 08:41 PM
jagboy's Avatar
did the code ever come back again? or did you find the issue?
Old Jul 27, 2013 | 04:29 AM
egis's Avatar
On decel/coasting I got --- on AEM wideband.never saw 20.
Jaws567
24
Jun 1, 2021 08:25 AM
06' Evo IX
Mar 3, 2020 11:42 AM
edbighead
Nov 1, 2011 02:43 PM
solipsism
Nov 28, 2009 04:56 PM
Lowness
Dec 20, 2004 11:13 AM
