Looking for all EVO 8, 9 people with 6 speed still.
Old Mar 16, 2019 | 10:14 AM
  #346
kikiturbo's Avatar
Originally Posted by Pal215
After having my 5 speed for 110,000 miles I switched over to the JDM MR 6 speed. Just over 1,500 miles on it now. Only using the pump gas 91 map for now which makes a little over 450whp. Have done no testing with E85 map yet. Fluid is REDLINE 75w-90NS GL-5 recommended by TRE and it shifts like butter once it's warm. When cold it can be a little notchy. I wonder if switching to MOTUL GEAR 300 75W90 would fix this. Other than that, no issues whatsoever. I love the gear distribution and the sorely needed 6th gear.
I ran my 6 speed on motul and it was fine apart from the second gear which would be ok when shifting fast but a bit notchy when doing a slow shift.. However, that was always connected to a worn clutch... with new clutch it shifted nice.. so it is no just about the oil..
Old Mar 16, 2019 | 11:46 AM
  #347
Lumpy Sticks's Avatar
5 Year Member
So it seems that the 6 speeds in general have a common issue of a notchy 2nd gear when cold? If so, that's good to know. I thought there was something wrong with mine. As far as I know, mines been on OEM fluid since day one.
Old Mar 16, 2019 | 12:15 PM
  #348
kikiturbo's Avatar
yeah, but when your clutch wears and starts dragging a bit then it gets real bad.. I used to go directly from first to third in the city, and that worked best for me..
Old Mar 16, 2019 | 01:04 PM
  #349
5 Year Member
I think my clutch is worn for sure. Chatters pretty bad when cold. It's the OEM one with 60k on it. I have noticed that if I push the clutch in, wait a second, then shift to 2nd, it's always smooth.
Old Mar 16, 2019 | 02:50 PM
  #350
Jp7's Avatar
Jp7
My 6 speed evo 9 had a notchy engagement into second the very first day I brought it home with only 4 miles on it. I had the trans upgraded by shep in september 2014 with the higher strength parts and I change the final drive (made it taller). After the rebuild 2nd is smooth like the other gears. My trans did not fail in any way, I just wanted it upgraded to handle more power (which I am now making on a built 2.3)
I have put about 1,500 miles on it since then and it still shifts good.
PeteyTurbo
205
Dec 10, 2024 06:04 AM
manthny18
Apr 4, 2017 03:09 PM
ChicagoEvo9
14
Jun 29, 2016 04:26 PM
DanielM
Mar 28, 2016 05:35 PM
Evo MR IX Fritz
Mar 2, 2016 04:04 PM
