2.0L enging upgrade,need your advise!
Old Aug 9, 2012 | 07:43 AM
babaz7's Avatar
hi i have a stock motor right now,but im planning to upgrade the internals...i already have cams and a gt35r turbo..
im settled on cp pistons and manley i beam connecting rods,is this a good option ?
and what compression pistons do i get? im planning to turn up the boost upto 2.2 bar...
and also what bearings should i get?
Old Aug 9, 2012 | 07:43 PM
evolvd276's Avatar
if its a low milage motor do drop in / std. size pistions you wont have to even pull the motor next id go with higher compression if you are doing e85 or higher octane race gas for high boost if not factory will be fine do your head right and get a good porting job and thats one hella combination with a large turbo
Old Aug 9, 2012 | 10:36 PM
babaz7's Avatar
we only have 93 octane here, and my car has about 50,000km, so i use standard bore or .5mm above?
and what compression is good for 93 octane and over 2 bar...
9.0 or 9.5?
and i would do a good porting job but i dont trust the people here,its better not to do it..
Old Aug 9, 2012 | 11:03 PM
evolvd276's Avatar
stock bore and 9.0cr will do you fine the head will give you the most gains towards your pump gas goal
Old Aug 9, 2012 | 11:28 PM
babaz7's Avatar
the combo i want has only 9.5cr, how much boost is safe for 9.5cr?
Old Aug 10, 2012 | 01:53 AM
KGB_KGB's Avatar
What about putting on the GRP aluminium rods
Any reason you choose Manley I beams
Old Aug 10, 2012 | 04:28 AM
babaz7's Avatar
hi im buying from ebay,this is the link... http://www.ebay.com/itm/CP-Forged-Pi...ht_4075wt_1037
they dont have aluminium rods, otherwise i'd get them.
how much HP can aluminium rods handle??
Old Aug 10, 2012 | 04:32 AM
babaz7's Avatar
will these buschur spec grp rods couple with cp pistons?
http://www.ebay.com/itm/Mitsubishi-E...r#ht_933wt_962
Old Aug 11, 2012 | 03:25 AM
KGB_KGB's Avatar
I believe up to 1200bhp for the aluminium rods! I might be mistaken.
I am looking to buy the 156mm aluminium rods from GRP.
Anyone has a set for sale? I believe waiting time is around 2 weeks or so.
I am not sure how it would be for a daily driver.
Old Aug 11, 2012 | 06:42 AM
babaz7's Avatar
im set on buschur spec grp rods and cp pistons, can anybody tell me is this a good combo and should i go for it?
and with a full built head can i rev my 2.0 to 9000 rpm's?
thanks!
CosmotheJTAC
Jun 5, 2015 12:56 PM
DirtyRalli
Aug 25, 2014 02:56 PM
gallas
Jun 9, 2013 07:27 PM
06mr775
10
May 15, 2013 08:09 AM
Xenozx
Jan 12, 2012 05:45 PM
