overboost evo 9
Old Aug 28, 2012 | 11:16 PM
rickygotanevo's Avatar
overboost evo 9
hey guys, Im having a problem with overboosting. Ive looked in forums and havent really found anything.
I put a 3'' hks highpower turbo back exhaust on and it ran fine, a couple days later i installed an hks ssq blow off valve. then it started over boosting!? so i turned my boost controller all the way down to have it run on waste gate boost which from what i hear is about 11 pounds, and im still over boosting!?
the BOV is not a recirc and its installed correctly.
Can anybody help me out? Or give me any ideas, any help is appreciated.
THANKS!
Old Aug 28, 2012 | 11:20 PM
fastyouth1313's Avatar
Boost controller failure
To run true wasgate psi only what you need to do is...
Take the vacuum line from the turbo j pipe and run it directly to the wastegate it should be around 16-17psi
Old Aug 29, 2012 | 05:40 AM
GTijoejoe's Avatar
Do what he said ^^^
Old Aug 29, 2012 | 06:09 AM
evo8426's Avatar
I would remove the bov, it is known to be a waste of money and a hassle to get running on the Evo. Since something is wrong revert back to the stock DV and see if your problem is fixed.
Old Aug 29, 2012 | 07:43 AM
sparky's Avatar
I agree with evo8426 on this issue. Since the problem arose after installing the HKS VTA BV, then the 1st step in my opinion would be to revert to the default, factory, recirculating piece and see if this cures the problemo.
Old Aug 30, 2012 | 11:48 PM
thank you everybody for you input, i should be getting tuned this weekend so i will live with it.
just wanted to make sure it wasnt anything serious
Old Sep 2, 2012 | 01:31 PM
silvrflyr's Avatar
So how did it turn out?
Wayne99gsr
Northwest Region
16
May 26, 2011 08:25 PM
itsu
Apr 28, 2011 02:16 PM
Braden71790
33
Dec 13, 2010 10:46 AM
ikt
Jun 21, 2010 03:38 PM
