Aem Tru boost overboosting
Old Apr 28, 2011 | 08:49 AM
itsu's Avatar
I just got done installing AEM tru boost controller on my IX,and Everything works fine except for i'm completely overboosting hitting 25+ psi, My duty cycle is set at 10%,and my crack pressure at 1. Is there something i'm doing wrong? I thought the lower the duty cycle the lower the boost pressure.
Any suggestions are greatly appreciated.
Old Apr 28, 2011 | 12:00 PM
Jrah2987's Avatar
Veteran: Air Force
I recommend changing the crack pressure to 11.5 - this has a big affect on spiking.
Give it a pull, but keep your eyes on your psi and a/f ratios... o and the road also.
Good luck.
Old Apr 28, 2011 | 12:47 PM
DSMolition's Avatar
What is your A and B settings? What is it set on? You could be set at a higher duty cycle on the b setting and not know it.
Old Apr 28, 2011 | 01:26 PM
itsu's Avatar
Thanks guys, I beieve Both A and B are the same, but I will double check. I just dont see how running the lowest duty cycle would pass 25 psi no problem. I thought running a larger crack pressure would spike more?
Old Apr 28, 2011 | 01:40 PM
binh's Avatar
hallman pro ftw
Old Apr 28, 2011 | 01:49 PM
DSMolition's Avatar
Double check your vacuum line routing.
Originally Posted by binh
hallman pro ftw
If you like to pull over and pop the hood everytime you want to increase psi then sure. You are also able to log with the aem unit. The aem unit is nice and super simple.
Old Apr 28, 2011 | 02:16 PM
itsu's Avatar
Yeah i upgraded from the hallman es mbc, thats why i'd rather not go back haha.
jetxjosh
Evo X How Tos / Installations
Mar 12, 2016 05:39 PM
twinspoolin94
Oct 15, 2015 05:28 AM
101516
29
May 4, 2014 05:28 PM
JohnBradley
Jan 24, 2010 01:16 PM
Sicks
Sep 25, 2008 08:37 AM
