Twin Scroll stock Frame With External Wastegate
Old Aug 29, 2012 | 12:01 PM
JSPturbo's Avatar
Hello,
I have installed a stock turbo with a flapper wastegate welded. I use the stock manifold with 44 wasegate discharge only in the 1 and 4 cilinder exhaust manifold.
There is any problem about this? I have some problems about amount of lag with this configuration.
The turbo is a td06 25g with 10.5 housing.
Thanks!!
Old Aug 29, 2012 | 12:20 PM
03whitegsr's Avatar
It's a terrible idea to only vent 2 cylinders.
Old Aug 29, 2012 | 12:49 PM
ineedmorepsi's Avatar
I would mount the EWG to a custom o2housing with WG flapper removed. Similar to this
http://www.atpturbo.com/mm5/graphics...-023_450-3.jpg
Old Aug 29, 2012 | 05:45 PM
sparky's Avatar
Originally Posted by JSPturbo
....I....installed a stock turbo with a flapper wastegate welded......The turbo is a td06 25g with 10.5 housing.....
You have lost me here. How can it be a stock turbo and at the same time a TD06-25G? Probably I am not quite up to speed on the nomenclature. But, still I don't understand what you are talking about.
Let's not even get into why you are doing whatever it is that you have done to a perfectly good Evo. You are not really in Spain. More likely a castle in Transylvania, huh? This is a joke from some dude over on the Subaru boards, right?
Old Aug 29, 2012 | 09:02 PM
RSMike's Avatar
Hello,
Thanks!!
This is a bad idea. you are bleeding the pressure off one of the scroll's only. This will cause a turbine housing failure quickly.
Originally Posted by ineedmorepsi
This is also a bad idea. This will increase boost threshold by 500-800rpm, making for a very laggy car.
If you have already welded your internal wastegate shut, i would recommend adding a wastegate pipe from runnings 2+3 to your existing pipe. Make sure they are divided all the way to the wastegate valve.
Example pic
This keeps the scrolls seperate until the wastegate valve opens.
Cheers, Mike
Old Aug 29, 2012 | 09:05 PM
RSMike's Avatar
another example
this is a T4 setup
Old Aug 29, 2012 | 11:33 PM
94AWDcoupe's Avatar
dude really?? you were warned it would be laggy. reread posts 109, 115, 118.
https://www.evolutionm.net/forums/ev...-thread-8.html
there is nothing wrong with venting only one side of twin scroll. I have a factory mitsu 24v twin scroll turbo here with factory internal gate that only vents one side of scroll. scrolls are not sealed from one another. pressures equalize at turbine.
Old Aug 30, 2012 | 07:18 AM
JSPturbo's Avatar
yes sir, you're right and I doubt yet
Now I bought a new exhaust housing and tested with a internal wastegate.
Thanks Again !!!
EriCS
Feb 17, 2012 08:05 AM
stevolution84
18
Nov 27, 2011 08:39 AM
W2J
Jan 30, 2010 07:49 AM
TKEVO
Mar 7, 2008 10:20 PM
subrwho
10
Jun 15, 2007 04:43 PM
