BOV Sounds like someone kicked a dog
Old Sep 11, 2012 | 07:19 PM
thatguy5's Avatar
As the title states my turbosmart dual port bov has made some terrible sounds as if someone kicked a dog or tires chirping.
I have used my evo 9 bov as a control, all my vacuum lines are good, the bov is installed correctly, I even took to bov apart to clean and oil it, and on top of that i have played with the spring stiffness.Also I have the bov set up to run full recirc and the sound has not changed.
It does an excellent job at being a bov, it just sounds.. terrible as if something is off..
Old Sep 12, 2012 | 07:31 AM
jrblackSE's Avatar
your 9 bov when you put it on works fine then?
Old Sep 12, 2012 | 07:35 AM
Montini06's Avatar
control - a standard against which other conditions can be compared in a scientific experiment
Old Sep 12, 2012 | 07:44 AM
fastyouth1313's Avatar
have you taken a control test to kicking a dog? HAHAHA J/K man.
can you put a sound bite or take a video with it venting so we can hear?
Old Sep 12, 2012 | 08:22 AM
Ev0ikon's Avatar
Unless you run a lot more boost than stock level, put the stock 9 back in.
Stop kicking the dog if it's only a control test! You are welcome.
Old Sep 12, 2012 | 03:50 PM
thatguy5's Avatar
Well i figured out the problem
turns out the bov was at a couple degree bend so part of the lip of my intake pipe was overlapping with the recirc port of the bov, causing a tiny bit of air to escape between the intake recirc port and the silicon coupler holding the whole shebang together. (God it sounded terrible)
the remedy was i relocated the bov on top of my short route intercooler pipe and just switched the silicon hoses around. Now it sounds like any other bov
Old Sep 12, 2012 | 03:51 PM
prowakeskater's Avatar
thanks for making me spit my drink out. kicking a dog? lol
Vivid Racing
12
Jul 30, 2014 03:40 PM
Jiggbobo
Jan 27, 2013 05:49 AM
HoPeLeS
Nov 28, 2012 10:56 AM
MatcoBill
Sep 25, 2012 03:41 PM
