Air Conditioner
Old Sep 18, 2012 | 10:36 AM
evokinevo's Avatar
Air Conditioner
Got a question. Hope this is the right spot to post. My car started making a funny noise like a grinding sound. It happens when my a/c is turned on. Once i push the button to turn off the A/C it stops. It doesnt make it with the just the fan on, Just the A/C. Would that be a compressor or the belt? Appreciate the help. I wanna avoid any issues before i do my Evo 9 Turbo conversion next month.
Old Sep 18, 2012 | 09:17 PM
barneyb's Avatar
Well, my car at idle with the A/C on makes a rattle sound like a diesel truck at idle - always has. So, I think this is normal.
I suggest you buy an engine stethoscope (harbor freight) and check where the sound is coming from. Be careful around the belt as it can ****** the probe and pull your hand in. But, like I said, the engine with the A/C on can make some funny noises and this is normal.
Old Sep 19, 2012 | 02:49 AM
evokinevo's Avatar
wow! yeah it just started yesterday. Sounds like a train coming down the tracks. lol
Old Sep 19, 2012 | 04:53 PM
mrowka's Avatar
From: Driving ten under in the passing lane, right turn signal on at all times.
Mine does the same. Not too loud, but you can hear it.
Old Sep 19, 2012 | 05:06 PM
kailoma679's Avatar
From what you are describing it sounds like an A/C clutch bearing... You can just buy the clutch I think from the dealer and make sure u shim it properly..
Old Sep 19, 2012 | 08:09 PM
barneyb's Avatar
I thought of that too but the pulley bearing is running when the A/C is off. When the compressor clutch is energized the shaft turns with the pulley.
kingjhay723
12
Mar 23, 2014 07:13 PM
mrowka
Jul 21, 2013 08:13 PM
BoostedAWD91
Sep 17, 2012 03:21 PM
Tbtalon94
AEM EMS
Jun 14, 2012 07:02 AM
EVO8LTW
Nov 1, 2009 08:36 AM
