AN Fuel Line Help
Old Oct 31, 2012 | 09:30 AM
Evo_AK's Avatar
Veteran: Air Force
AN Fuel Line Help
Sorry if this has been asked before or in the wrong section, I searched and couldn't find anything. Here's my dilemma:
I'm upgrading my intake manifold to a Skunk 2 and decided to add some other things like FIC 1100, AEM Fuel Rail, and FB 70mm throttle body. I'm doing AN fuel lines to get rid of the OEM hardlines out of the engine bay. Does anyone know how I can connect the OEM hardline to a -6AN hose? I was thinking this, but didn't know how much it would work.
http://www.ebay.com/itm/FRA-280206-F...d0072c&vxp=mtr
Old Oct 31, 2012 | 11:57 AM
jessmanEVO's Avatar
IIRC, I used this fitting... http://www.jegs.com/i/Earls/361/9816...oductId=749370
The NPT side will just screw onto the nut thats on the stock fuel feed line.
Old Nov 1, 2012 | 10:43 PM
mrfred's Avatar
i have yet to find a good adapter to convert from the oem hardline coming from under the car to AN fittings. its a really rare inverted flare. earl's has an adapter but it looks dicey because it seals with an oring rather than using the flare.
Old Nov 1, 2012 | 10:49 PM
masonh's Avatar
i yanked the hardline which is too small anyway and replaced it with -6an Aeroquip Startlite race hose or you could use steel bradied,teflon or push-lock hose as well.
the hardline comes out real easy and you can pull the plastic tabs between the troughs to make one trough big enough for the -6an line which is .625" OD.then since the clips back up.
Old Nov 1, 2012 | 11:04 PM
mrfred's Avatar
here is a proper adapter:
http://www.ebay.com/itm/Fuel-Line-Fi...sories&vxp=mtr
as masonh said though, putting in a short section of AN hose is not going to help much with flow.
Old Nov 2, 2012 | 02:59 AM
TommiM's Avatar
http://www.speedsourceusa.com/index....hard-tube.html
here is a nice kit to adapt from a hardline to an.
Old Nov 2, 2012 | 04:43 AM
Spec-Ops1's Avatar
Dang, Mrfred found an adapter that is actually made specifically for this!
Old Nov 2, 2012 | 07:54 AM
mrfred's Avatar
Not the correct fitting for the factory hardline on an Evo.
lol. Too bad its $30. It should be about $5-10. Wierd is why Earl's or Russell don't make a proper fitting rather than a screwball o-ring fitting.
Old Nov 2, 2012 | 08:47 AM
Evo_AK's Avatar
Veteran: Air Force
I'm debating this but I think I'm gonna go with a Buschur or Full Blown double pump and just run it all the way back. Then just make things easier.
Old Nov 2, 2012 | 09:49 AM
Spec-Ops1's Avatar
I just priced everything out and with that fitting, hoses and all fittings to go to the aeromotive rail it was a lot more than I was willing to spend... I think I am good with the OEM lines LOL
Old Nov 2, 2012 | 02:10 PM
masonh's Avatar
for economy push-lock is definitely the way to go.off the top of my head you could get a 10 micron filter,the fittings and the line for under $150 and have -6an all the way from the double pumper to the rail.i bought a good high flow fuel filter from Jays racing with barb fittings on it for i think $70.10 feet of hose should be $30 or so and the push-lock fittings are cheap,then you need the $25 rail fitting.
i would guess getting the -an double pumper,-an filter and running the braided hose with crimp fittings would cost at least double,but you could get a hose with a tougher shell and some would argue the crimp fittings are better than push-lock.personally i think the push-lock is the **** and if you like reassurance you could even clamp or double clamp the push-lock fittings.
i bought my EVO 8 already setup with AMS rail,but the factory hard line was still there.the guy i bought it from had a fuel pressure gauge installed in between the hard line and the rail and the fitting used on that pressure gauge actually had an ID of under .200" which was yet another bottle neck and also the flares on the factory line go down to under .200".i just figured making everything .375" would have to help.
i have read some people say not to use rubber or flexible lines,but i think the push-lock stuff will work.i know guys running it successfully.the startlite race hose has a push-lock inner hose with a Kevlar/Nomex shell.
Old Nov 2, 2012 | 02:47 PM
Evo_AK's Avatar
Veteran: Air Force
I'll probably end up doing the Buschur Double Pump with -6AN fittings and run them to a Y and go -8 to the fuel rail. Then a -6 return to the FPR and actors hardline from the FPR to tank. I don't mind the cost of everything. I just want to be satisfied the first time with it.
Old Mar 27, 2018 | 11:47 PM
MR ArcticC's Avatar
I tried to remove the stock fuel line from the hard line. The fitting is tight and I didn't manage to open it. Does it have normal threads, so it opens counterclockwise?
Any tricks to open it without twisting the hard line? I wan't to install a new fuel line+filter between the fuel rail and hard line.
Old Mar 30, 2018 | 09:04 AM
tauro91's Avatar
Best would be to run Holley performance Earl's Speed flex PTFE hose it's rated for 1500psi and carbon lined for fuel. -6 from each pump into a Y block and -8 speedflex hose into a walbro 10 or 40 stainless steel filter and -8 again into fuel rail. Upgrade would be ultrapro hose but the crimping tool for that alone is like 2k.
Old Apr 2, 2018 | 10:49 AM
mrfred's Avatar
I don't recall it being counterclockwise thread. Can't see any reason why it would be either. Try Liquid Wrench or PB Blaster?
letsgetthisdone
39
Dec 31, 2018 03:07 PM
Asmodeus6
Jun 9, 2016 09:26 AM
R/TErnie
For Sale - Cars For Sale
15
Sep 1, 2015 10:23 AM
ezcape
Mar 27, 2015 05:38 AM
alpinaturbo
Nov 24, 2013 10:20 AM
