Engine Rebuilt - Oil Pressure Light HELP!
Old Nov 16, 2012 | 08:26 PM
90blackawdtsi's Avatar
Originally Posted by AreSTG
I doubt it makes that much difference... (sarcasm)
I'm just saying
Old Nov 16, 2012 | 08:34 PM
chu's Avatar
chu
Originally Posted by TurboTravis
Waste of money going to the 'break in' oil. Off the shelf VR1 has more than enough zinc/phos for the engine at any given point in it's life.
If it was mine, I'd put in VR1 20W50 tomorrow. And as much as the botique oil supports would like to agree, any off the shelf 20W50 has ample zinc/phos for the motor, unless you're running a FP journal bearing turbo, in which case the VR1 has plenty.
I don't want to argue about boutique vs. store brand. I already have the oil, so I'm not going to waste it. I wasn't expecting the issue when I rebuilt the motor. The thought never even cross my mine to run 20w50 until now.
Old Nov 16, 2012 | 11:15 PM
TurboTravis's Avatar
Yeah, fill it right up with something that's probably going to give you even less oil pressure. Good choice!
Old Nov 18, 2012 | 06:33 PM
chu's Avatar
chu
So I ended up putting in 20W50 Castrol GTX. Haven't had a chance to check out the oil pressure yet as I was busy all weekend. Have to travel for work this week, but will do that and report back.
Old Dec 4, 2012 | 11:16 AM
chu's Avatar
chu
So it's been a while since I've followed up with this thread. Been very busy with work. Anyways, I got a cheap oil pressure gauge on the car not too long ago. Since the post, I change the OEM pressure switch for a new one, and also switched to 20W50 as I mentioned in the last post. I no longer get the oil light in the dash. What I forgot to mention in the original post is that I have deleted the oil cooler with the STM kit.
As of last night, I'm getting 25psi on cold start, and 12 psi warmed up. A local guy who has a 2.3L build told me his was around 11psi also. So I proceeded to check oil pressure at different RPMs. I did this by just revving up in neutral, not drving around.
25psi @ 2K
45psi @ 3k
60psi @ 4k
60psi @ 5k
Any advice if this is okay. Should I be seeing higher pressures? Is this normal for not putting the motor under load by driving it?
Old Dec 4, 2012 | 11:38 AM
jasnm21's Avatar
I have way higher oil pressure than you do... I have a built 2.0, Wiseco pistons, Manley I beams, oil cooler and balance shaft delete kits, Brad Penn 20w 50 and my idle is around 40 when warm, and cruising is at or around 80-90 psi. I pm'ed a pretty big shop about the pressure and he said it was perfectly normally pressures for my setup.
I know when I was stock block the pressure was much much less. The thicker the oil, the less it travels through, oil cooler and BS delete, the higher the pressure will be.
Old Dec 4, 2012 | 11:46 AM
chu's Avatar
chu
Thanks for your response. I hear alot of people say stock is around 15-20 when warm, although I've also seen some people say their's is really low. My buddy with a nearly stock IX gets 13psi at idle. I notice you said 80-90psi when cruising. I haven't driven the car yet, which is why I don't know what my cruising pressure is.
clanzkiller
24
Jun 15, 2014 03:33 AM
Pitside
Mar 5, 2014 12:43 AM
Tibbar
Feb 1, 2014 07:50 AM
THUB
Aug 9, 2012 06:12 AM
StlEvo05
24
Mar 10, 2012 08:31 AM
