HKS EVC 5 help!!
I need some help...all directions on my MBC are in chinease and i wanted to know if anyone had any directions or if anyon eknows how to use it....i need to know KPA conversions and how to raise boost on the MBC, im stuck at 19 and wanna see what power i can make around 21 22...thanks so much!!
http://www.worldwidemetric.com/metcal.htm
here is a site where you can do all the conversions for bar to psi and so forth. I use it since my gauge is in bar.
its tunred up 100% on a and b settings, it only goes to 19 psi, it should max out 36 psi 100%, we cant figure out how to go past that 19 psi mark, its the HKS evc5, im reading the box as we speek....
First off check all your hoses for leaks. Second, are you using the stock rubber hoses for the EVC solenoid. If that is the case, it might be the problem. Stock lines contain a pill to restrict boost, somewhat like a filter. You need to replace these lines with silcone ones. If neither is your situation, I have no answers for you.
pruven performance installed it, i know in my stock lines the bost pill was already removed when i ran my (cough sucks) EXEDE ( cough)....so I have a feeling it is a function on the display that we are not understanding or not using, all directions were in Japanease.....anyone know what 187 kpa equals into PSI lbs.???
LOL, my post got deleted for stating my opinion about Xede. Well i guess Al got banned to for defending himself again shiv and his butt buddy MP5.
This is to Xede
This is to Dynoflash
Go ahead delete my thread because it is OFF TOPIC!!!
I DON'T CARE!!!!!!!!!!!!!!!!!!!!!!!!!
This is to Xede
KOEvo
Jan 12, 2007 12:46 PM
