loude ticking noise
Old Nov 25, 2012 | 06:14 PM
kaczordd123's Avatar
loude ticking noise
hey my car wasnt started for 3 weeks, i started it up yesterday and i noticed this loud ticking sound that wasnt there before,
it sounds exactly like in this video i cant upload my video for some reason
Old Nov 25, 2012 | 06:53 PM
TheReal94_tsi's Avatar
Sound wont work for me , how cold was it and whats your oil type?
Old Nov 25, 2012 | 07:03 PM
fastyouth1313's Avatar
That's the way my Viii sounds.... Let me know what you find out
Old Nov 25, 2012 | 07:23 PM
i was runing amsoil 20-50w oil, i changed it to 10-30w mobil one today and still sameee sound it gets louder when i drivee and my A/F ratio is going lean/rich back and forth its around 35-40 degrees in ny
Old Nov 25, 2012 | 07:31 PM
im thinking one of the lifters collapsed or bled out when it sat not driven for a month
Old Nov 25, 2012 | 10:13 PM
3K's Avatar
3K
If you have cams I wouldn't worry about it. Practically every Evo with cams sounds like that. Including mine. Now if your on stock cams, I really can't say what it would be. maybe really loud injectors? j/k
Old Nov 26, 2012 | 06:41 AM
Well i am woried cuz the noise wasnt there hahaha it sound just like in the video and gets louder when i drive
Old Nov 26, 2012 | 07:56 AM
barneyb's Avatar
Since a rod bearing can't go bad while the car is parked for 3 weeks, I'd suggest a new set of lifters. If that doesn't cure it then I'd suggest checking the bearings and wrist pins.
As for the fuel mixture problem, do you mean it goes rich/lean when in closed loop, because that is normal, or open loop because that isn't.
Old Nov 26, 2012 | 09:13 AM
yeah rich/lean in closed loop, so im guessing thats normal
Old Nov 26, 2012 | 12:43 PM
And for some reason car runs lean
Old Nov 26, 2012 | 10:38 PM
barneyb's Avatar
You probably need to look at your tune.
Old Nov 27, 2012 | 07:18 AM
I found it! Got exhaust leak where downpipe conects to 02 housing
Buguy
Jun 1, 2015 03:10 AM
Ichigo0Soul
21
Mar 26, 2014 05:43 AM
wolford240
Oct 28, 2013 11:55 AM
evohmoob
Aug 27, 2013 03:50 PM
usernameinuse
Aug 16, 2013 02:11 PM
