stock uicp install / pic request
Old Dec 5, 2012 | 12:28 PM
Tmosser's Avatar
Well im in the process of putting stock uicp on my car had a supermarket on. Im having a hard time lining the brackets up on both lower and upper pipe. Can anyone snap a pic of how they bolt to the frame or tell me how exactly.. I got them on but their just on not bolted down on brackets so rubbing on the frame and lower rubbing on black piece which holds the horn. if it matters i have a aem intake tube w perrin filter
Thanks!
Old Dec 5, 2012 | 01:54 PM
pupo's Avatar
Here is one that I had when it was stock:
This one I got it from the web, hope it helps:
Old Dec 5, 2012 | 04:19 PM
Tmosser's Avatar
eh kinda but cant raelly tell where it bolts to. Thanks tho
Old Dec 5, 2012 | 09:08 PM
Tmosser's Avatar
Here are some pics off my car showing whats not bolted up/rubbing and i have no idea where they bolt.
Yes my engine bay is kinda a cluster right now, with swapping the stock uicp and trying to get the stock air box to fit which it is not right now because of this problem.... and lastly needed to do a little vac line re arranging and tucking so there isnt so much extra line.
Old Dec 6, 2012 | 12:23 PM
Tmosser's Avatar
Bump anyone?
Old Dec 6, 2012 | 04:13 PM
llDemonll's Avatar
what's confusing about the pictures that Tmosser posted? you're not going to get much better
Old Dec 6, 2012 | 04:26 PM
Tmosser's Avatar
Huh? In the pics i posted you can see none of the piping is bolted up. I am asking where do they bolt up to, and what am i doing wrong for them not fitting correctly. The piping is rubbing on the metal and driving me nuts when I drive the car.
Old Dec 8, 2012 | 12:51 PM
Tmosser's Avatar
Bump other wise im just gonna have a shop grind off the brackets so they dont rub, when I get em power coated.
Old Dec 8, 2012 | 04:32 PM
Frew's Avatar
The upper pipe bolts to the stock air box bracket that bolts to the driver side frame rail. The lower cold side pipe bolts up under the body by the acd pump.
Old Dec 9, 2012 | 11:57 AM
evo8426's Avatar
If this doesn't help I'll take a few pictures today
Old Dec 9, 2012 | 03:15 PM
pupo's Avatar
This is where the pipe bolts up under the car, I am using your picture:
There should be a rubber piece on the pipe that is missing. Take a look at the first picture that I shared with you you can see that you have the anble wrong on that pipe.
Old Dec 9, 2012 | 03:27 PM
pupo's Avatar
It is hard to see here but look at this one:
Old Dec 10, 2012 | 10:28 PM
Tmosser's Avatar
Awesome!!! Thank you!!!
Evo9MRkidd06
Apr 7, 2012 07:17 PM
xceler8rob
Northwest Region
Nov 28, 2010 10:00 PM
Paulito
Mar 9, 2010 06:39 AM
dudical26
25
Jun 8, 2007 05:47 AM
petersa9
10
Jan 26, 2004 06:51 AM
