Gm 3 port boost solenoid problem..
Old Dec 19, 2012 | 04:23 PM
ReaperX's Avatar
Originally Posted by tscompusa
not at all. I'm just implying i don't feel its in the rom causing the issue. i will certainly update and let you know what the issue is once we figure it out. i am going through troubleshooting steps right now with him.
I am thankful you guys actually are here to help him to begin with, because sometimes i don't have time to trouble shoot cars right away.
I have seen a lot more helping going lately as opposed to when I first got on here a few years ago. Seems everyone is a little more educated in troubleshooting than before.
I always treat folks on here like I do at the track. If you don't have the tool for the job and I do, you're welcome to it. If I don't have the tool, I'll point you in the right direction to get it.
Old Dec 19, 2012 | 06:23 PM
GTijoejoe's Avatar
^^^ He'll figure it out.
I'd suggest also reloading the same file just in case, I've had strange things happen sometimes on flashes.
Old Dec 20, 2012 | 01:53 AM
tscompusa's Avatar
well said. i agree with everything you said. thanks again.
ya it looks like it was in the rom afterall. the wastegate must have been fighting with the WGDC %. I had the WGDC to low in the main map. upped it a bit more and all is well.
I guess i am used to customers with preloaded wga's so i figured the 52% or whatever i had in there would be sufficient for a base test pull. turns out that only gave around 15psi. upped it a little more and now hes around 17psi and the fluttering is gone.
thanks again for helping him guys.
Old Dec 20, 2012 | 05:28 AM
GTijoejoe's Avatar
Sounds about right.... too many times I've tried hunting down mechanical issues when they've been tuning, thinking "its impossible its a tuning issue"
Glad to hear its worked out.
brusinn
10
Sep 3, 2013 05:53 AM
markex
Aug 11, 2012 05:48 AM
MagicManRed
Oct 25, 2011 10:57 PM
rolly1818
May 8, 2010 03:14 AM
JMB8606
Dec 4, 2008 03:53 PM
