Boost Problem
Old Dec 29, 2012 | 03:35 PM
Evoryder's Avatar
looks ignition related...plugs/coils
boost leak is always recommended
Old Dec 29, 2012 | 03:53 PM
Gordian79's Avatar
Update i went out for a spin and literally spun out on the snow.Its still doing it.I disconnected 2nd fuel pump to make sure that wasnt the issue and it still did it.I didnt really get to get it in boost because it kept spinning.I switched bov to pull mode seems to work well that way too.Im gonna look into ignition gonna pull the plugs and put stock coils back on to see what happens.Plugs dont even have 100 miles but you never know ive had new plugs f up.
Old Dec 29, 2012 | 04:08 PM
fastyouth1313's Avatar
what plug you using?
Old Dec 29, 2012 | 04:27 PM
Gordian79's Avatar
bpr8es
Old Dec 29, 2012 | 04:44 PM
Originally Posted by Gordian79
bpr8es
thats what i was going to recommend if you had different lol.
one other thing though. when i gapped mine one time i kinda scared up the L shape piece that you adjust for gap, when i pulled it, the part that was scared up was very black and looked to be a hot spot. non the less i tossed it and but a new one in. no problem since
just food for thought.
Old Dec 29, 2012 | 07:29 PM
Gordian79's Avatar
plugs look like they could use some more timing.That or faulty ignition.
Old Dec 29, 2012 | 10:06 PM
At least it's clue on where to start diagnosing, or put you hand on intake and look for puffs of smoke like that fruit cup said
Old Dec 30, 2012 | 06:49 AM
Spec-Ops1's Avatar
You have stock coils or a cop?
Old Dec 30, 2012 | 09:49 AM
Gordian79's Avatar
No puffs lol
Cop but i put in stock setup to see if thats the problem.
Old Dec 31, 2012 | 11:11 PM
Gordian79's Avatar
Update:I think i found the problem.One of the pumps(main pump) in double pumper was off its rubber.It was dangling.clamp that holds pumps together was loose and vibration wiggled pump off. so basically when i was going under load the y was sucking air.I will update once i get everything in there.
Old Jan 1, 2013 | 07:34 PM
Ghostdriver22's Avatar
I dont drive it much and last time i drove it started bucking when going into boost.I have grimmspeed ebcs but its disconnected.FP Black FP 25 psi wga,Synapse dv in push mode.In the video below i connected wga to compressor elbow it should be around 18-20psi.
http://youtu.be/OvShe5hmCI8
What is your youtube channel?
Old Jan 5, 2013 | 10:15 PM
Gordian79's Avatar
No luck yet pumps are back in and car continues to run like crap.Tried stock coils and cop.Tried new plugs.
Old Jan 5, 2013 | 10:39 PM
marrrk's Avatar
i had very close to the same thing from what it sounds like, about a year 1/2 ago in my case it was the acuator the 25# on a jb red, diaphram was f---- up, replaced it and all was good. be nice if you had one you could swap it out with maybe? anyway hope you get it sorted out over the winter. and by the way, love your race car
Srt4...
Jul 19, 2015 04:46 AM
Jush
Feb 23, 2014 06:40 PM
CDrinkH2O
47
Oct 17, 2012 08:13 PM
BluEVOIX
23
Aug 24, 2010 07:24 PM
cij911
13
Mar 28, 2010 02:18 PM
