BOV Flutter?
Old Dec 29, 2012 | 05:08 PM
OC's Avatar
OC
BOV Flutter?
I'm a noob at this kinda stuff so I need your guys' opinion. I have a Evo 9 with a tbe aem intake and a turbosmart bov. Am I supposed to hear flutter when I'm just cruising allow speeds shifting into gears. (ex. 20-30 2 gear into 3) and a psssh after I get on it? Or do I have to tune it a bit better? I heard that's how I'm supposed to have it. It doesn't flutter when I get on it tho. Thanks you guys
Old Dec 29, 2012 | 05:13 PM
fastyouth1313's Avatar
The flutter is fine. The spring inside the turbosmart is just tight not allowing it to open fully. Your fine though.
What turbosmart BOV you using?
triple L's Avatar
when it flutters it means ur bov is not fully open to release air so it backpressures ur turbo... that is the fluttering sound u hear... the reason u hear phhh is because ur into more boost and valve opens fully... this is normal but i would recommend setting ur bov to a softer spring or if u have twist it where it opens easily
Old Dec 29, 2012 | 06:06 PM
OC's Avatar
OC
I have the turbo smart dual port bov. How soft should it be?
Old Dec 29, 2012 | 06:17 PM
Well loosen it until it stops fluttering. But if your going to a race day or you know your going to be doing WOT pulls then tighten it back down
Old Dec 29, 2012 | 11:43 PM
OC's Avatar
OC
How loose should I have it? And when is it too much?
Old Dec 29, 2012 | 11:44 PM
triple L's Avatar
^^^ -exactly
Old Dec 29, 2012 | 11:46 PM
triple L's Avatar
im not quite fond of the turbosmart bov but there shuld b a + and - u wuld want to set it to more to + ....try it out and drive it around the block u shuld notice the difference
mrfred
537
Jun 20, 2022 09:50 AM
tsitalon1
61
Feb 28, 2019 02:44 PM
lpy2009
Feb 26, 2012 12:09 PM
IspyEvo
14
Apr 23, 2010 11:06 AM
joon82
12
Jul 8, 2007 05:52 AM
